Old 05-19-2008, 04:12 PM
milkman milkman is offline
Default Pro Tools is unable to communicate with HUI
Guys & Gals, I did the DUC search with no help so I'm asking for yours. Win XP Pro, PT 7.1, Projectmix. I was running this setup w/no issues using the Firewire 410. I bought a Projectmix lightly used and downloaded the drivers. I didn't get a manual or discs so I'm pretty much in the dark. My first issue is this constant error message,"Pro Tools is unable to communicate with HUI. Power-cycle HUI and check it's connections. Note, if HUI is not in use, update the Peripherals dialog to prevent further warnings". Waddaya think? The drivers came from the M-Audio site but the install screen didn't look like the one on the website. One matter I didn't mention is that I was testing the waters with a project I had recorded with the Firewire 410 and not a new project... does THIS make a differance? Thanks for any help.
I'm just a average Joe with 10 thumbs trying to figure out where the heck the current flows.
Old 05-20-2008, 08:27 AM
TechKnowledgy TechKnowledgy is offline
Default Re: Pro Tools is unable to communicate with HUI
I'd suggest start by trashing Pro Tools Preferences and then setting up the PMI/O as a HUI controller again.
Old 05-20-2008, 12:45 PM
I'm not sure what the PMI/O is, so if you or anyone else can break it down for me it would be great. Also, on the perferances issue, are you suggesting all of the boxes checked in Pro Tools under the setup menu? If so, what is "trashing"? Does that mean to uncheck them and restart then recheck them and restart? Thanks for your help.
Old 05-20-2008, 01:41 PM
spkguitar's Avatar
PMI/O = ProjectMix I/O
Digidesign has created a Tech Support Utility that has an easy way to "trash" preferences and databases.
Old 05-20-2008, 02:27 PM
Thanks to TECHKNOWLEDGY and SPKGUITAR for responding and helping me with this issue. I solved the problem by going into PERIPHERALS under setup (TECH'S SUGGESTION) and switching the "send to" under Midi Controllers to Digidesign1 as it was checked as Projectmix External Midi! It was amazing, I pressed the enter button w/my thumb to change paths and POW!!!! The Projectmix came to life! I hope this helps another newbie.
Pro Tools is unable to communicate with M-Audio Keyboard mstreacy Windows 27 11-08-2017 08:22 AM
Pro Tools unable to communicate with HUI MCU. earshatter Pro Tools M-Powered (Mac) 2 11-17-2016 12:56 AM
Pro Tools is unable to communicate with HUI. thingfish_mpowered Pro Tools M-Powered (Mac) 17 01-29-2016 04:18 PM
Pro Tools unable to communicate with control 24 stipe ICON & C|24 2 09-20-2006 11:40 AM
Pro Tools is unable to communicate with HUI Gilfigga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 09-22-2003 06:57 PM
