Old 11-28-2007, 09:18 PM
boutwell boutwell is offline
Default Channel name LED\'s not working
anyone experiencing problems with the LEDs that display channel names ? mine have suddenly gone so dim as to be unreadable. all other indicators/lights still functioning.
Old 12-01-2007, 05:19 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Channel name LED\'s not working
This sounds like a connector inside has come loose! quite common and you'll need to open her up and check all connections and cables are clean and tight. they are conected in banks of eight, so you should find the cable connecting those eight leds
Chris
Producer, Engineer,
www.ukmastering.com
Old 03-31-2008, 10:04 AM
NakedI NakedI is offline
Is this still the solution if all 24 channel name LED's go dim on the Control 24. Is this a power supply gone bad problem or just a connection problem.
drxe
Musician, Keyboardist, Producer,
Engineer, Programmer, Songwriter
www.nakediinc.com
[email protected]
Old 04-04-2008, 09:34 PM
Rich Breen Rich Breen is online now
Yup - I must've had mine out 5 or 6 times cleaning those stupid molex connectors for this exact symptom - oh, also a good stiff rap on the back of the supply would often take care of it for a while... Finally got a new C24.
best,
rich
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Digi 002 - optical input not working / only DI channel 1 working Maulden7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-07-2013 01:46 AM
Phantom power not working on ONE channel of C24 conrad787 ICON & C|24 1 12-01-2010 03:59 PM
Reference channel in Sonnox not working. Bug? SD2 Post - Surround - Video 8 02-16-2010 05:01 AM
No LED's working just faders faxbear ICON & C|24 1 04-10-2008 05:00 PM
ProjectMix channel strips not working joemusic Pro Tools M-Powered (Mac) 25 10-22-2007 01:53 AM
