Old 09-19-2006, 06:51 AM
stipe stipe is offline
Default Pro Tools unable to communicate with control 24
Help. I am running pro tools 6.2 on a mac with a control 24 surface. It was running fine for about 2 months after the power supply fried and I had it replaced. I was recording a session and the error "pro tools unable to communicate with control 24" came up. I checked the ethernet settings and everything seems to be normal there but it is still offline. I can still record but without automation. If anyone has had the same problem or knows what's up, I'd appricate any info. Thank you so much.
Old 09-20-2006, 03:54 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Pro Tools unable to communicate with control 24
Have you tried reset from the ulitities menu? and then re assign it from PT setup peripherals menu etc.
Are the lights on the back of the ethernet socked on?
can you test the ethernet port on your computer? connect it to another computer or something to check it?
Chris
Producer, Engineer,
www.ukmastering.com
Old 09-20-2006, 11:40 AM
I will try those options. Thank you for your time.
Pro Tools is unable to communicate with M-Audio Keyboard mstreacy Windows 27 11-08-2017 08:22 AM
Pro Tools unable to communicate with HUI MCU. earshatter Pro Tools M-Powered (Mac) 2 11-17-2016 12:56 AM
Pro Tools is unable to communicate with HUI. thingfish_mpowered Pro Tools M-Powered (Mac) 17 01-29-2016 04:18 PM
Pro Tools is unable to communicate with HUI milkman Pro Tools M-Powered (Win) 4 05-20-2008 02:27 PM
Pro Tools is unable to communicate with HUI Gilfigga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 09-22-2003 06:57 PM
