Old 12-12-2005, 06:38 PM
blizzard's Avatar
blizzard blizzard is offline
Default I play a \"C\"................I hear an \"F#\"
Hey Everyone!
I am using an Oxygen8 with Reason (2.5), rewired into PT (6.4). For some reason when I play a middle C (C1) on the keyboard, I hear an F# (F#1).
But when I trigger a C(C1) using the keyboard map on the left side of the edit window in Reason, it plays the correct note.
It seems like perhaps a midi setting has changed that I am unaware of. I have checked through the midi settings within PT and Reason but I can't seem to find anything thats different. Anyone experienced this or have any troubleshooting ideas?
Greatly appreciated!
Cheers,
blizzard
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9
Old 12-12-2005, 08:30 PM
markblasco markblasco is offline
Default Re: I play a \"C\"................I hear an \"F#\"
Most midi keyboards have a transpose feature. Have you checked the keyboard to make sure it is not set to transpose everything up?
Old 12-13-2005, 03:11 AM
neeel neeel is offline
I had this issue once before and am not really sure how I fixed although I know what made it happen in the first place.
I had reason 2.5 rewired to PTLE7. The only affected module in reason was the Malstrom. When I had reason rewired to the stereo MIX L, Mix R it worked perfectly but as soon as I rewired the malstrom to its own input i.e. channel 3 on a mono aux track in PTLE I noticed a changed pitch.
Neil.
MBOX MINI PTLE 8.0.3
MAC OSX Snow Leopard
Mac Mini 1.5Ghz Intel
2 Gig RAM
Can't hear myself play without recording AdamEdinburgh Pro Tools SE and Essential (Win) 18 06-07-2020 08:33 PM
Play and hear instruments in record enable 028 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-16-2018 11:25 AM
Cant hear input in play mode Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-17-2009 05:46 AM
beginner - can't hear my mix when I try to play it back Elita 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-04-2008 06:35 AM
I play a "C"................I hear a "F#" blizzard MIDI 1 12-13-2005 08:44 AM
