Old 12-12-2005, 06:28 PM
blizzard's Avatar
blizzard blizzard is offline
Default I play a \"C\"................I hear a \"F#\"
Hey Everyone!
I am using an Oxygen8 with Reason (2.5), rewired into PT (6.4). For some reason when I play a middle C (C1) on the keyboard, I hear a F# (F#1).
But when I trigger a C(C1) using the keyboard map on the left side of the edit window in Reason, it plays the correct note.
It seems like perhaps a midi setting has changed that I am unaware of. Anyone experienced this or have any troubleshooting ideas?
Greatly appreciated!
Cheers,
blizzard
DAW - ProArt B550-Creator / 5950X / 128GB / WD SN850 1TB / PT 2023.9 / RME UFX+
Macbook Pro Retina / 2.8GHZ / 512GB SSD / PT 2023.9
Old 12-13-2005, 08:44 AM
Stig Eliassen's Avatar
Default Re: I play a \"C\"................I hear a \"F#\"
I'm not familiar with your keyboard, but the problem could be due to keyboard transpose or "frozen" pitch bend status. You haven't transposed your keyboard by accident?
Also, controller info can sometimes get stuck. Should be enough just touching the pitch bend while the track is record-enabled/ receiving midi.
Can't hear myself play without recording AdamEdinburgh Pro Tools SE and Essential (Win) 18 06-07-2020 08:33 PM
Play and hear instruments in record enable 028 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 03-16-2018 11:25 AM
Cant hear input in play mode Greg555 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 08-17-2009 05:46 AM
beginner - can't hear my mix when I try to play it back Elita 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-04-2008 06:35 AM
I play a "C"................I hear an "F#" blizzard 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-13-2005 03:11 AM
