error DAE 7400
Windows xp/digi 002 rack/ pro tools 6.1.
I got a error message " DEA 7400 "...what its meen??? I can't run some plug'in since I got this trouble!!! I change the playback buffer but no change !!! plz help me!!! |
Re: error DAE 7400
This is the Mac side for Protools LE but I will give it a shot.
In the answer base this is one of the causes you will find. If you do a search you will find others. This error is caused by permissions settings on the plug-ins not allowing specific users Read & Write access. To change permissions on a plug-in, locate it in /Library/Application Support/Digidesign/Plug-Ins/ Select the file and choose Get Info > Ownership & Permissions, click on the lock icon and enter your administrator password, then change the Group permissions to Read & Write Alternately you can drag and drop the plug-in from the PT 6.0 installer CD, however, this will not allow other User Accounts on the same system to use that plug-in. In the PT 6.0 CD-->application support folder-->digidesign folder-->plug-ins folder. Drag to the OS 10 hard drive-->Library folder-->Application Sup't folder-->digidesign-->plug-ins. ID:26568 Created:04/03/2003 Hope this helps. |
Re: error DAE 7400
I appreciated your detailed "permissions error" explanation in your post. I too, had the DAE error -7400 just today and after changing permissions, all is working perfect! This OS X permissions thing (Or should I say UNIX thing) is starting to drive me crazy. At least I'm better protected security wise I guess ?!?
Error 7400, Would really appreciate help ! | Wayfaerer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-23-2010 09:16 AM |
DAE Error -7400? Help! | Stixntrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-25-2009 12:33 PM |
KEEP GETTING DAE error 7400 | dwayne00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 03-18-2009 03:00 PM |
DAE error 7400??? | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-29-2006 12:23 PM |
Auto Tune Error----- DAE Error -7400??? | Lance Driskell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-06-2005 01:51 PM |
