Old 12-16-2023, 02:10 AM
Default Re: Dante DVS audio glitches - how best to configure?
Just a quick side-note: DVS does not use QoS tags. QoS only comes into play when using Dante hardware cards so Dante packets coming from DVS won't get priority when you setup your switches properly.
https://www.audinate.com/learning/fa...do-not-use-qos
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron
Old 12-16-2023, 02:40 AM
uptheoctave uptheoctave is offline
That is a very good find.
Thank you.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 12-16-2023, 04:07 AM
Thank you.
This live engineer has very good write-ups on Dante on his blog with details on the "fine print" that is not easy to find @Audinate:
"So if there is a bottleneck somewhere in the network, then the data from true Dante devices is preferred, as long as QoS is set up accordingly on all switches. Data from the DVS, on the other hand, cannot be recognized by the switch as audio data and is the first to be lost in case of doubt."
https://www.jochenschulz.me/en/blog/...-disadvantages
https://www.jochenschulz.me/en/blog/...-use-multicast
https://www.jochenschulz.me/en/blog/...switch-feature
https://www.jochenschulz.me/en/blog/...tch-topologies
(more on his site...)
Old 12-16-2023, 04:16 AM
That it even better.
Cheers.
James Richmond
Affiliate Links:
Old 12-19-2023, 08:20 PM
citysoundman citysoundman is offline
Thanks Frank for the info & links, Super helpful!
Bob Kirschner
NYC-based Audio Post Mixer/Sound Designer
bobkirschner.com
FS: Dante VIA and Dante Virtual Sound Card henningaround Buy & Sell 0 12-29-2021 02:04 AM
Can't configure M-Audio Keystudio binaural42 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-31-2010 02:44 PM
How To configure 003, Protools and JK Audio Innkeeper 1x jbayfield 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-05-2010 08:30 PM
How do i configure the 001 audio ports for cubase? PTInc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-29-2002 12:46 AM
Digi001 configure with Logic Audio PC?!? joepanic 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 03-10-2002 07:23 PM
