Old 02-10-2019, 11:34 AM
innerbooty innerbooty is offline
Default Problem with plugin / send insertion during Playback
I sort of bounce back and forth between PT 9 HD on one drive and PT 10 HD on a 2nd drive, but mostly in 10 these days. In PT10 lately I was noticing that when I add a plugin or insert during playback, after the plugin or insert is added, playback returns the timeline location where I started playback instead of just continuing, which is annoying. Unless I'm totally spacing out and it's been working this way the whole time, I'm wondering why it doesn't just continue playing from the point in the timeline where the play head was when I added the plugin. Isn't PT just suppose to pause playback while the plugin/insert is added, and then just pick up from where it was? Is there a setting to toggle this? I don't see one at first glance...
Thanks for any tips!
Insertion follows playback Philharmonic7 Avid S4/S6 4 04-20-2017 12:46 AM
Playback insertion problem?? Smithcok 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-15-2009 04:03 PM
Problem with "Timeline Insertion Follows Playback" Chris7514 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-14-2008 09:43 AM
insertion follows playback KingTor ProControl, Control|24, Command|8 5 05-22-2001 04:23 PM
