Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 08-27-2018, 06:31 PM
truthmonger truthmonger is offline
Default MBox (3rd Gen) incompatible with USB3 in Windows 7, 8 and 10 - Use USB 2 port only
Recently my Mbox (3rd Gen) stopped working on my Windows 10 PC. Instead of functioning for audio output, the Mbox would crash Windows 10 with a BSOD.
The failure seemed to begin when I moved my PC to a new room, which involved unplugging and replugging my cabling.
After doing all manner of deinstalling and reinstalling drivers, I finally came across a clue on the page http://avid.force.com/pkb/articles/e...d/Mbox-Drivers where it says, "USB 3.0 Ports not supported with Windows 7." I guessed that maybe this statement was not up-to-date and that the same USB3 incompatibility also exists in Windows 10. BINGO! This was the answer.
I moved my Mbox USB cable from my USB 3 port to a USB 2 port and VOILA, it started working again. Pity for those with newer PCs that have only USB 3 ports.
I found this solution perplexing, because the USB 3 spec is supposed to be backwards compatible with USB 2. So the Mbox should work on either type of port. It's disappointing that whatever is causing this USB 3 incompatibility has not yet been solved with an updated driver. Until then, just use a USB 2 port, and you're golden!
This problem was so troublesome, yet so simple to solve, I just had to share.
Old 08-28-2018, 06:51 AM
Southsidemusic's Avatar
Default Re: MBox (3rd Gen) incompatible with USB3 in Windows 7, 8 and 10 - Use USB 2 port onl
For those with new PC machines without USB2 ports, just use a USB2 hub from a USB3 port. Easy, cheap ( $15-$20 ) and you are set.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
For Windows users, review of Apollo Twin USB3 VRW Third Party Interfaces 0 09-18-2016 08:09 PM
Pro tools 12 incompatible with windows 8.1? Padraig Pro Tools 12 11 04-20-2015 04:53 PM
Mbox USB3 issues samtherobot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-09-2013 12:55 AM
pro tools m powered 7.3.1 incompatible with windows 7?? braegen russell Pro Tools M-Powered (Win) 5 05-13-2010 08:40 PM
ProTools and Windows Vista: unsupported, or incompatible? Geoff Hague 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-09-2007 09:15 AM
