Old 10-22-2005, 01:26 PM
GothicV GothicV is offline
Default If it runs a 001, it should run a 002r, right?
I have seen the light [of 7.0] and want it. I am selling a bunch of stuff in Vancouver, BC Canada, check out my post in the For Sale section of the DUC if you are interested... but more importantly...
My PC runs PT perfectly, no crashes or anything. Can I expect the same from the 002r I plan on buying, or do I have to just play the cards and see?
Old 10-22-2005, 01:29 PM
JMS40 JMS40 is offline
Default Re: If it runs a 001, it should run a 002r, right?
Compatability between the 001 and 002 is different.
001 is PCI based... 002x is firewire.
As such, the 001 doesn't have the SP2 problems seen by firewire and USB hardware. And the interaction with the chipset is a whole new ballgame.
You'll want to make sure your current system is compatable with the 002 specs... even if it runs the 001 flawlessly.
Long line runs between 002R and computer? John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-17-2005 08:49 AM
Looks Like OS X, Runs On XP... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 07-13-2004 08:47 PM
Which version of DP runs best w/ 002R, OSX, G-5?? R Mauleon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-29-2004 04:57 PM
Which Mp3 runs on OS X? JimCutler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2003 01:42 PM
PTF runs on a PII 233 Mhz Taja13 Digidesign Hardware & Software 1 10-26-2000 11:14 PM
