Old 02-06-2010, 10:51 AM
oulablank oulablank is offline
Default !!! Setting display on imac from millions to thousands turns PT YELLOW !!!
Digi says when optimizing your mac for PT try putting display settings to thousands instead of millions . This worked on a power pc but on an imac ( i've tested 3 so far ) thousands will cause almost everything in PT to be yellow. If this is happening to you don't panic ! Quit PT , change display back to millions , restart and launch !
Cheers
Old 02-06-2010, 11:07 AM
sunburst79 sunburst79 is offline
Default Re: !!! Setting display on imac from millions to thousands turns PT YELLOW !!!
Cheers
This is kinda old news....Are you using a current getting started guide or applying old settings? I thought those optimzations died with the G4/G5.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-06-2010, 01:52 PM
This is coming out of the 8 getting started.
Old 02-06-2010, 02:20 PM
Avid's Avatar
Avid Avid is offline
Administrator
Can you tell me which PDF document specifically so that I can look into it? I think that sunburst's question is valid, I wasn't aware that recommendation was current, but I would definitely like to check.
Administrator
Old 02-07-2010, 03:41 PM
As soon as I get home ( which will be tomorrow ) I will scan it . I must say that thinking about it that it could have been on the site . I'm pretty sure it was the getting started manual but it could have been in the mac help on digi's site. Either way if it's my manual I'll post it but if it's the site then check again because whichever one it was was current . I'll get back to you asap .
Sorry about the burst sunburst .
Old 02-09-2010, 04:02 PM
gthm's Avatar
gthm gthm is offline
try putting display settings to thousands instead of millions.
Silly question.. Where do you find this thousands/millions option? There's no such option in Displays within System Preferences. Sorry, display dummy here!
Why is my display YELLOW!? starsdilate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-03-2008 03:21 PM
Setting up dual display monitors, please help songman0412 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-25-2007 04:07 PM
Little Yellow Box Lines in Arturia's Minimoog V Display??? RokVox Virtual Instruments 7 04-18-2007 11:44 AM
Little Yellow Box Lines in Arturia's Minimoog V Display??? RokVox 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-12-2007 11:38 AM
Help! 02 turns on, but display doesn't show text! cosmicevan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-22-2006 02:18 AM
