Old 05-02-2008, 07:11 PM
rost rost is offline
Default TPkd error & pace error trying to install that too
So I have XP sp2 and I just purchased PT 7.4. It installed fine but launching it gives the TPkd error. I looked up the error and it points me to http://www.paceap.com/dldrvr.html to download the XP driver. I do that and launching the setup.exe gives an other error. Error reading setup installation file.
Now I dont know what to do. Help digidesign please!!!!
P4 3gig 1g ram XP
iBook G4 1gig
G4 AGP 450mhz ( upgraded to 800mhz)
1gig ram
MBOX PT Le 6
ART Tubepak
Mackie Vlz 1202
Old 05-03-2008, 07:05 AM
Default Re: TPkd error & pace error trying to install that too
the tpkd is for anti piracy reasons and p.t. wont launch w/o it. you might have to uninstall pro tools and try it again. be sure to restart your machine before and after you uninstall and reinstall p.t. make sure you downloaded the 32 bit version.
pro-tools-pc.com
TRASHER Pro Tools Utility(updated 4-11-2024)
Intel I7 9900k
Win 10
Old 05-03-2008, 08:24 AM
The real problem is pace's install will not even run. I will try to uninstall PT7.4 but it was a fresh install and I have nothing but mcaffee on XPsp2.
P4 3gig 1g ram XP
iBook G4 1gig
1gig ram
MBOX PT Le 6
ART Tubepak
Mackie Vlz 1202
Old 05-03-2008, 07:50 PM
UNINSTALL MCAFEE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
pro tools and anti virus do not get along in any way. at least shut off mcaffee AND your firewall while installing and when running pro tools!!!!!!!!!!
pro-tools-pc.com
Intel I7 9900k
Win 10
Old 05-03-2008, 08:53 PM
sunburst79 sunburst79 is offline
FWIW WebRoots Internet Security Suite is a PT killer also - At least with the FW interfaces.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 05-04-2008, 08:50 AM
I have tried uninstalling PT74 disabled Mcafee and reinstalled. Same error regarding TPkd. I have tried both versions of INterloks 32 and 64 bit apps. Both say "Error reading setup initialization file".
P4 3gig 1g ram XP
iBook G4 1gig
1gig ram
MBOX PT Le 6
ART Tubepak
Mackie Vlz 1202
Old 05-04-2008, 10:51 AM
Out of curiosity do you have any FAT 32 formatted drives? or drives with long file names? Is the computer using any language other than english? File compression turned on?
The cannot read file error has me puzzled.
7.4 dropped support for FAT32, There is a issue with logical drive names over (as I recall) 11 characters, There have been some issues with PT and languages that use ascending and descending characters and PT does not like file compression or drive indexing. If you have drive indexing or compression turn it off on all drives.
You are rebooting after you uninstall the TPkd driver? I had a issue once were I had to uninstall the driver and reboot twice before it would completely uninstall the driver and let me update it. I have also seen the multible copies of the driver installed and you should check that there are no additional entrys in the Add Remove/Pograms list.
You will also need the Pace Interlock Drivers
The TPkd should be bit the 32bit version.
I suspect that something is amiss in the registery or file system at this point but am not sure where to tell you to look. You might try one of the free registry cleaners out there. While I have not tried personally it I have heard good things about CCleaner. If you don't have a lot of data on the new install it might not hurt to reformat since it may be faster than trying to troubleshoot it.
Last but not least... Have you done all of the steps in the windows General Troubleshooting thread as far as system set up and configuration? Its importent to do this as it eliminates a lot of potential problems and levels the playing field for anyone trying to help you troubleshoot.
Scott
Core 2 Specs Page
Old 05-04-2008, 12:50 PM
Well, I got frustrated and wiped the PC. I didnt have anything on there so it was no big deal. A fresh install and all the XP updates + Quicktime. Now PT74 installed and runs!!! It did prompt me about the long file name and I changed the HDD name to "C". Lastly I installed McAfee.
It all works now!!!!!! No prompt about TPkd or anything. All is good!!!
Thanks everyone for the help. I dont know what was the issue but it works now.
P4 3gig 1g ram XP
iBook G4 1gig
1gig ram
MBOX PT Le 6
ART Tubepak
Mackie Vlz 1202
Old 05-04-2008, 05:13 PM
Glad its going! Hopefully the rest will be smooth sailing for you.
If I had to quess I suspect it may have been the long file name, Digi should probably mention this issue in the general troubleshooting thread.
Scott
Core 2 Specs Page
Pace Register Error during reboot after fresh install of PT 8 DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-14-2010 05:23 PM
Tpkd (PACE) driver and Audacity daeron80 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-28-2009 09:25 AM
TPkD Error D-TalkX Pro Tools TDM Systems (Win) 1 03-09-2008 06:01 PM
Initialization Error TPkd GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-21-2008 11:11 AM
TPkd PACE rgr VENUE Live Sound Systems 8 05-06-2006 11:02 PM
