Old 05-29-2006, 02:50 PM
pancake1975 pancake1975 is offline
Default MIDI Output Problem - Assigning MIDI Patch Names
Hello,
I am using Pro Tools LE 6.9.2 for the Mac. I have used Audio on this extensively with no issues. I recently got interested in MIDI but have encountered some problems. I have been able to record MIDI and during playback I see a signal coming out but hear no audio. I believe I have a problem in assigning a MIDI Patch File.
Here is what I have done:
In the MIDI Setup I have added a MIDI Device
I go to the Output in the Mix view and choose Digi002 and select Channel 1
I click on the program button to select a patch.
No patch name files have been assihned so I select a patch and click change.
I choose the same patch file (.midnam) that correlates the MIDI Device I set up in MIDI setup.
I then get an error message:
Pro Tools will not let you import a patch name file that does not match the model and manufacturer information that you have selected in the MIDI Studio Setup window
Not sure where to go from here. Any help would be greatly appreciated.
Thanks.
Old 05-29-2006, 02:53 PM
Default Re: MIDI Output Problem - Assigning MIDI Patch Names
pancake1975
What external MIDI device are you using?
filosofem
Aaron Mulqueen - 001 HD Native
Old 05-29-2006, 02:56 PM
Thanks for the quick response. For input I am using the M-Audio Keystation. I have been playing everything through the digi002 rack. Am I missing a piece of hardware?
Old 05-29-2006, 03:02 PM
Right ...ummm so your using software synth's?
What softsynth program are you using?
filosofem
Old 05-29-2006, 03:04 PM
Sorry. New to the whole MIDI thing. Anything you could recommend?
Old 05-29-2006, 03:08 PM
What came with your Pro Tools bundle? Install one of those, for starters.
filosofem
Old 05-29-2006, 03:12 PM
Cool. Will try it.
Thanks for your help.
Old 05-29-2006, 03:22 PM
pancake1975
Once you have installed your softsynth's, insert them in a MIDI/AUX setup or a Instrument track if your Pro Tools version is 7.x and select the Patch's from the softsynth itself.
To my understanding MIDI Studio Setup is for routing External hardware MIDI devices, not software devices. Although I have heard that question been asked before.
filosofem
Old 05-29-2006, 03:25 PM
Excellent.
Will do.
Thanks for clearing things up.
MIDI Patch Names - From MIDI Forum DigiTechSupt MIDI 75 04-17-2024 10:15 AM
How to restore Midi Devices & Midi Patch Names JLEpperson Pro Tools TDM Systems (Mac) 1 12-31-2009 12:31 PM
Midi patch names from DP to PT rinky MIDI 0 01-28-2007 02:47 PM
PT6 and MIDI PATCH NAMES usinare Pro Tools TDM Systems (Mac) 10 03-08-2003 08:12 PM
PT5 & OMS Names Manager (MIDI patch names) Baron Von Deca Tips & Tricks 0 02-17-2000 03:55 PM
