3rd party interfaces and hardware inserts latency
I'm considering replacing my HD Native, HD Omni and HD I/O with Apogee Ensemble Thunderbolt or UAD Apollo 8. I frequently use parallel processing using external analogue gear. The latency of I/O inserts is perfectly compensated. Is this also going to be the case with Ensemble and Apollo or am I going to run into problems?
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
Re: 3rd party interfaces and hardware inserts latency
You will have to enter the latency values of those interfaces in the I/O menu manually, they are not automatically calculated and compensated for like with HD hardware..
It's hit or miss and one of the reasons I eventually bought HD native hardware because it never seemed to work correctly, at least for me.
www.montabonsound.com www.29counts.com Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection |
It *should* work, if you input the right latencies. Which may take measuring at your particular sample rate. I've done it with non-HD gear fine. UAD Console and plugins in the console might confound things.
What are the values for Apogee Ensemble Thunderbolt?
It seems that Aurora Thunderbolt doesn't need any adjustments in I/O Setup:
http://www.lynxstudio.com/forum/foru...are-inserts-pt Quote:
Hardware insert latency as well as loopback recording latency were perfectly compensated. So it seems that properly created Core Audio drivers take care of it. No need for any latency adjustments in the I/O setup!
Anyone know? Thx. |
Low Latency Monitoring with 3rd party interfaces - details? | Rich Breen | Pro Tools 10 | 13 | 10-26-2011 02:19 PM |
Third Party ASIO / Core Audio Interfaces and Hardware Inserts ADC ?? | ajv205 | Pro Tools 9 | 8 | 12-18-2010 11:13 AM |
latency when using hardware inserts (oo3) | earmeter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 07-14-2008 06:38 PM |
[002R] Hardware Inserts Latency: how much is it? | HotRats_Reloded | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 06-14-2006 01:03 PM |
latency on hardware inserts | vtone | Tips & Tricks | 4 | 10-22-2000 05:37 AM |
