192 I/O Interfacing S/PDIF to AES card-SRC not working
I've got a TC Electronics M350 collecting dust and want to use it through the digital i/f so I can keep my 8 analog I/O's. The M350 only has s/pdif and will only do 44.1k and 48k. I've verified it works with the enclosure spdif and AES ports, but only at 44.1 and 48k. I do a lot of work at 96k, so I thought I could use the SRC in the AES card. I built these cables, substituting the XLR pin outs for the 25 pin dsub:
AES to spdif cable spdif to AES cable I then set up my hardware and busses to use it as an insert and set it up to use SRC. It works in the AES connector, but only at 44.1k and 48k. When I switch to 96k the DI indicator on the M350 blinks indicating the digital input signal is corrupt, probably because the SRC isn't converting. I've looked at the spec for IEC-958 and TC electronics says the M350 processes all 24 bits, so it should work, and it does, but only up to 48k. Am I misinterpreting what the SRC is supposed to do? Has anyone done this? Any ideas?
Mac Pro 6.1, E5-2690 V2 10 core 3.0G, 32gig 1866 memory, 512G PCIe system drive, 4 480G OWC 3G SSD data drives in Thunderbolt 2 enclosure, macOS 10.15.7, Pro Tools Ultimate 2020.9.1, Twin Raven MTi's, Apollo 8 TB, 2 UAD2 Satellite Octo Thunderbolt, RME ADI-4 DD, Neve 5012, 5043, Bricasti M7, 2 PCM 92's, M350, DynAudio BM6 MK 3, BM14S, a bunch of cool mics...1 damned iLok2. |
Re: 192 I/O Interfacing S/PDIF to AES card-SRC not working
SRC only works on the inputs. If you have a 96k session then your interface is outputting 96k signal which the TC does not understand.
well, the M350 would make a nice paperweight, except for the sharp edges...
003 S/PDIF not working | amdini | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-06-2015 05:02 AM |
AMIII S/PDIF in from Second Audio Card S/PDIF Out? | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-04-2005 10:30 AM |
S/PDIF out on 001 not working | jonesaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-21-2005 12:31 PM |
Anyone know of a s/pdif pci card? | mlemos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-23-2004 12:46 PM |
S/PDIF in not working?? 001 | Mike F | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-24-2003 07:21 AM |
