Old 09-12-2020, 02:27 AM
Teej Teej is offline
Default Switch vs router and crossover etc... (S1 and iPad)
Networking is not my specialty, please help me figure some basic stuff out!
I already know that an Artist Mix plugged directly into my Macbook Pro with a cat5e x-over works. The Artist Mix works in tandem with my internet Wifi (usually tethering from my phone) so I don't have to switch between internet/controllers.
The plan: I have an S1 on the way and will eventually add an iPad to it as well. In the future I'd like to add a second S1 and possibly a Dock ... all with iPads at some point.
How do I do this?
Step 1: Single S1, x-over cat5e and done.
Step 2: S1 + iPad, Can I use the iPad with an ethernet connection with this set up? So I could get a switch instead of a router, keep everything wired and continue to use wifi only for internet connectivity.
Step 3: 2x S1 + 1x Dock + 3x iPad ... if the above is correct, I can get a switch at the beginning with enough ports for how much I want to expand and just plug-in as I aquire the gear.
Also, a couple basic networking questions:
For this application, can I connect a switch directly to my computer without a router? And if yes, should I be using normal cat5e or x-over cat5e between the computer and the switch, and between the switch and the devices.
Let me know if this makes sense or if I'm missing something. Thanks :)
Old 09-12-2020, 10:49 AM
Top Jimmy's Avatar
Default Re: Switch vs router and crossover etc... (S1 and iPad)
To be clear, you are asking about what’s known as an unmanaged switch.
Unmanaged switches are layer 2 devices that allow you assemble a LAN to connect all your local IP enabled gear. An ad-hoc network is simply the switch with neither a router nor a connection to a WAN. Ad-hoc networks require you to manually configure the IP addresses of everything connected.
You should get a switch and plug everything into it. Computer, controllers, wi-if access point, and connection to router and WAN all go through the switch using standard Cat5e or better cables. If there’s a router connected, it can dynamically provide IP addresses to everything via DHCP.
I believe Avid now recommends running their controllers via DHCP, but there’s no reason they can’t work manually on an ad-hoc network.
James Cadwallader
Old 09-12-2020, 05:00 PM
Thank you for all the information! You fixed a few wrong assumptions I had about networking and I think I've got the idea now. :)
Old 09-12-2020, 07:18 PM
Top Jimmy's Avatar
James Cadwallader
Router, Hub, Switch? pasanta Artist Series 1 08-02-2019 12:22 PM
Ethernet Switch or Router? simonjewel Artist Series 15 09-13-2015 04:09 AM
Best switch/router for Artist series? ThosSounds Artist Series 2 12-21-2014 04:16 PM
Mackie DL 1608 ipad mixer+Router for sale! Mitchbis Buy & Sell 3 10-07-2013 02:03 AM
Crossover or straight-thru for ethernet on switch? satsi ProControl, Control|24, Command|8 1 03-23-2004 10:01 PM
