Old 01-25-2002, 03:07 PM
Luiz F Luiz F is offline
Default Kurzweil K2000S and Mac G4
i want to record audio tracks using a kurzweil k2000S ... when i connect it to inputs 5 and 6 i hear no sound ... when i press a key on the kurzweil no sound comes out ... i'm not even able to play it back ... can anyone help me with the right configuration ?? something like " step by step"
PS:i'm not using an external mixer to output
Old 01-25-2002, 03:35 PM
Kickin.da.speaker Kickin.da.speaker is offline
Default Re: Kurzweil K2000S and Mac G4
Step 1) Make sure your K2000 is "on" [img]images/icons/grin.gif[/img]
OK let's get serious:
1) Plug a headphone in your K2k's headphone out. Do you hear a sound? Yes? Go to 3)
2) Don't hear a sound? Go to MIDI on the K2k's panel, select "Control" and make sure it's on "Local". Good.
3) Now plug the MIX outputs of your K2k in your input of the 001. I recomend the 3-4 so you can monitor the K2k bypassing your computer, but I don't know your set-up.
4) On your mixer strip, select "input 3-4" or "5-6" in your case, record enable, play...you should hear something, right?
Well, let me know how that goes and ask further questions if needed.
David.
6am eternal
Old 01-25-2002, 04:07 PM
GORILLA GORILLA is offline
Hey Luiz. We did the same as Kickin' desribed except we went into the front mic 1 and mic 2 and padded them!! Only problem we encountered was getting the samples back into the Kurzweil [img]images/icons/grin.gif[/img]
You can hear it here www.mp3.com/PRIMATE-GORILLA... it's "ACID RAIN"
METAL LABS
Old 01-25-2002, 09:43 PM
Targon Targon is offline
In program mode, with the current sound selected, hit the enter key to enter the program editor. Use the more > buttons to find the output page. Change the output assignment from A to C position the star in the center for signal to go out C L+R equally.
Remember if u plug a cable into the indivual outs, the signal WILL be REMOVED from the mix outs.
Targon
Old 01-26-2002, 02:27 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR> In program mode, with the current sound selected, hit the enter key to enter the program editor. Use the more > buttons to find the output page. Change the output assignment from A to C position the star in the center for signal to go out C L+R equally. <HR></BLOCKQUOTE>
There's no such thing as a C output on the K2000 synth. They have a A(FX) output and a B(DRY) output. The mix output, that I recommended for the tests, produces programs routed through either the A or the B output.
David.
6am eternal
Kurzweil Rumour? tele_player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-09-2004 10:29 PM
Kurzweil KSP 8 songman Tips & Tricks 7 10-12-2003 11:01 AM
kurzweil ksp8 all you need? sinew1958 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-06-2003 12:33 AM
Kurzweil PC2 digital out. APAULOS 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-22-2002 12:30 AM
Kurzweil,Kurzweil......2500.... petter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 12-06-2000 08:24 PM
