Old 10-16-2023, 12:55 AM
Echomix Echomix is offline
Default Re: New studio set up
The 13`MacBook M1 I was thinking about, has only 2 ports! Which makes me wonder how this will work with external interface, external HD , connecting to an external larger screen. And no special port for psu.
Old 10-16-2023, 01:39 AM
BScout BScout is offline
You'll need to get a thunderbolt dock. Quite a few actually charge the connected computer at the same time (you use the "host" or "90W" thunderbolt connector on the dock.)
So you get the thunderbolt dock and plug it into your power outlet, connect all your stuff to that (external displays, hard drives, audio interfaces, etc.), and then connect the host thunderbolt connector to your laptop (which will then charge your laptop)
Old 10-16-2023, 10:06 AM
Thanks! Very useful info!
Old 10-16-2023, 10:13 AM
JFreak's Avatar
JFreak JFreak is offline
Even if it is a "90W" charging dock, you may run out of juice when connecting external drive(s). Buy the most powerful dock/charger you can find.
Janne
Old 10-16-2023, 10:41 AM
"Run out of juice". Do you mean only "juice" ref. powering the Mac, or will this also affect signal quality from external devices connected?
  #16
Old 10-16-2023, 10:43 AM
JFreak's Avatar
If the dock says 90W and laptop needs 100W for charging, your external drive will not power up.
Janne
  #17
Old 10-16-2023, 04:18 PM
That 90W is for that one port only -- and I got the number wrong, it's 98W.
The other thunderbolt ports are to spec. The power is not shared between ports, it is just a guarantee of the charging port (Thunderbolt 4/USB 4 spec is 15W for general ports.) So there isn't any worry. If the charging port doesn't provide enough power, it just slow charges (much like on an airplane.) Airplanes only provide 75W. Apple has stayed within power limits for a long time. (other companies, not so much)
So there is nothing to worry about.
  #18
Old 10-17-2023, 03:45 AM
Thanks again, I really learn a lot from all of you guys ...-)).
  #19
Old 10-17-2023, 03:49 AM
JFreak's Avatar
Yes, it ultimately comes down to power source. You only get what is provided. AND, in this case it depends on the dock: some give priority to the charging port, so if charging port takes "up to 100W" and your power source gives 75%, chances are other ports get zero watts.
Janne
  #20
Old 11-04-2023, 03:46 AM
What is most important?
16 vers 32 GB ram
512 GB SSD vers 1 TB SSD
I am looking for a secondhand MacPro and some offer mac`s with 32 ram / 512 and some 16 ram / 1TB.
What is "most" important of Ram or SSD for running PT projects.
Desktop PCs w/ Win11 for Pro Tools Studio/MBOX Studio forumuseraccount1234 Pro Tools 0 04-01-2023 05:18 PM
Can ProTools Vocal Studio work in Pinnacle Studio 14.01.7256 Sharon Lee Taylor Pro Tools SE and Essential (Win) 2 08-28-2010 08:39 PM
Logic Studio taking files to pro tools studio. smoochdaddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 12-30-2009 10:55 AM
Studio Experts....Tips for studio design. H-man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-30-2005 06:08 PM
Studio interrior! Let's show them home/appartement /garage studio's :) Gr0und_Zer0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 200 05-18-2003 05:40 AM
