Old 07-23-2020, 08:25 AM
DBK DBK is offline
Default With SSDs becoming mainstream can pro tools now be on the main OS boot drive?
We all know with spinning hard drives it was advised to have pro tools sessions on a seperate hard drive. But I've heard countless time from reputable people now that with solid state drives that is no longer the case. I've heard this enough that I should just accept it but the OCD overthinking side of me still is skeptical about putting pro tools on my main Solid state drive, although this would be ideal for my drive situation.
I have 1 samsung evo 970 1Tb m.2 SSD and 1 samsung 970 evo 2TB drive.
What would be the ideal setup? I would prefer to have my operating system and pro tools on my main 1TB SSD and reserve all 2TB of the 2nd internal drive for my cpu/ram heavy sample libraries (eastwest, kontakt, UVI, etc..) but I can put Pro Tools sessions on either drive.
So which situation is optimal for performance. All drives are evo 970 m.2 SSDs
1. Having Pro Tools sessions run on my operating system drive with all of the applications and windows 10.
2. Having pro tools run alongside my sample libraries on my 2nd internal SSD.
3. (Only if necesarry) purchase a new SSD that will solely run pro tools sessions.
And while were at it, please explain to me why it's ok to have pro tools on an OS SSD now (if it is ok) so i can put this worrying to rest haha.
Old 07-23-2020, 08:36 AM
Default Re: With SSDs becoming mainstream can pro tools now be on the main OS boot drive?
All this has been on DUC already many times....
You can likely do whatever you want.
Things also are affected by use of disk cache, and wether VI samples stream or pre load.
Old 07-23-2020, 10:26 AM
Lynn Gräber Lynn Gräber is offline
Yeah, why not. With NVME I dont even use Disk Cache anymore.
Welcome to the 2020's. haha
Old 07-23-2020, 01:23 PM
Something to keep in mind is system maintenance. If you have your PT sessions on the same drives as your operating system and the drive fails you lose both the OS and sessions. Separate drives for OS and PT sessions alleviate that problem. Same for samples. For those reasons alone separate drives for os, PT session and samples might be a good thing.
Also keep in mind your backup strategy - you do have one right? You wouldn't necessarily need to have 3 separate drives but it wouldn't hurt.
Jack
QAPLA!
Old 07-23-2020, 08:33 PM
DBK DBK is offline
Oh yah I definitely have backups that I haven't mentioned - I just expect most people assume everyone backs everything up as they should be haha.
Losing the sessions wouldn't be a big deal as I'll have everything backed up, and losing the OS would be the same whether or not PT is on that drive or not. So the OS is gone either way, and the sessions will be backed up regardless. So I don't think I'll really lose much more in 1 scenario to the next if that main drive goes down. In both cases I lose the OS, and in both cases I have the sessions backed up. I would lose whatever work I'd been doing for the last couple hours assuming I hadn't backed up though, so theres that I suppose.
Old 07-23-2020, 08:34 PM
DBK DBK is offline
Any remembrance of what the thread was called? Would love to skim it.
Old 07-23-2020, 08:57 PM
google NVMe SSD boot samples site:duc.avid.com
542 results
google NVMe SSD "Darryl Ramm" site:duc.avid.com
1570 results
Using google search to search DUC is much better than the internal search.
Your questions also have no obvious deeper answers than just try it. We don't know if you are working the most complex huge post video sessions or doing massive VI work, with what VIs etc. And we have no idea what you mean by "performance", just Pro Tools not falling over (should not be a problem)? Session startup time? Session load into disk cache time? Sample load time? Ability to support massive streaming amount of VIs (should not be a problem). etc.
The simplest rule is that with NVMe drives none of the old rules apply, you can put everything on one drive, or in any combination of drives. Things like space needed for samples, planning for ease of backups etc. are more important than worrying about IO performance of the drives.
Old 07-23-2020, 09:52 PM
DBK DBK is offline
542 results
1570 results
Thank you
Old 07-24-2020, 08:08 AM
EGS's Avatar
EGS EGS is offline
...Using google search to search DUC is much better than the internal search...
+1
Click for audio/video demo
Click for resume
Old 07-24-2020, 08:48 PM
zion zion is offline
Same Here!
D-command main unit won't boot mark linett ICON & C|24 5 08-20-2011 07:35 AM
using external boot drive for main OS c s 0 1 Virtual Instruments 7 08-15-2009 04:47 PM
Pro Tools LE on boot drive only? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-17-2008 01:40 PM
Pro Tools LE on Boot Drive? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-14-2008 08:39 PM
Mixing mainstream... compromise creativity? Dr. Bockman General Discussion 4 01-07-2005 11:55 AM
