  #61
Old 03-01-2018, 10:17 PM
johndance johndance is offline
Default Re: New Avid S3 constant failing faders. ASC throws Visualforce error
Thanks Eddie. I appreciate the help... in in Hong Kong... so may be hard to get to?!?
  #62
Old 03-01-2018, 10:20 PM
EddieJones's Avatar
Yes, I was hoping for the US. Speak to your dealer and let me know what he says. I still might be able to track it anyway.
  #63
Old 03-01-2018, 10:25 PM
Ok. And just to confirm you think it sounds like the faders need replacement, or something else ?
  #64
Old 03-01-2018, 10:26 PM
EddieJones's Avatar
Sounds like bad faders, sorry.
  #65
Old 11-07-2018, 11:18 AM
The Saxplayer The Saxplayer is offline
FWIW I have had no issues now for a couple of months. My last swapping fader position thing seems to have worked....
EUCONTROL 18.3.0244
My Fingers are still crossed which makes mixing a bit awkward. :)
Thanks very much
Georges
The Saxplayer
  #66
Old 09-22-2019, 03:59 AM
Hi Eddie and the others,
yet another fader is making problems. This time it works sometimes, but most often not.
This will be fader number 4 that I will eventually replace.
There must be some explanantion.... ribbon, connecrtor seating? My board gets not as much use as it should so I cannot believe it's abuse.
Thanks very much
Georges
The Saxplayer
  #67
Old 09-22-2019, 08:01 PM
EddieJones's Avatar
What version of software are you on now ? Do you cover the S3 when not in use for a while, is it dusty etc ?
  #68
Old 10-07-2019, 01:19 AM
I am running the latest Protools and Eucon Versions. I do not cover the S3 but I have a soft paintbrush that I use regularly to keep my consoles clean.
But here is another Idea: I have disconnected the fader an reseated the little multipin and voilà... that particular fader is working again.
Could it be that there is some oxidation thing going on changing some values?
In a Mackie live console I own it is common practice to reseat the ribbon cables plus multipins about once a year. If not you may loose an output or have weaker signal.
Just a thought I had... can only confirm when the next fader starts to act on me :)
Thanks very much
Georges
The Saxplayer
  #69
Old 04-06-2020, 11:44 AM
Friends,
I think I found a solution to the failing fader issue.
The faders are not damaged. What you need to do is clean the connector where the fader's multipin sits in.
use Craig Deoxit or KONTAKT60.
I had a couple acting on me and this is the solution.
By the way I tried this because the same happens with a Mackie console and their ribbon cables.
Thanks very much
Georges
The Saxplayer
Avid Artist Community "Visualforce" error Airehnr66 General Discussion 0 04-04-2016 04:58 PM
Avid Profile Fader Bay Circuit Boards failing [email protected] VENUE Live Sound Systems 1 12-13-2015 11:07 PM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
What's the fix for a session that throws this message? albee1952 Pro Tools 10 2 06-05-2014 11:09 AM
Faders failing on some sessions lyoung1101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2007 11:55 AM
