Old 04-18-2017, 06:22 PM
Rajsmoove Rajsmoove is offline
Default Re: New Avid S3 constant failing faders. ASC throws Visualforce error
Originally Posted by EddieJones View Post
Can I ask anyone with a fader that keeps failing to do this and let me know what happens after you reset it and its working again. Make sure you have tracks on the surface and then tap on the top panel around the suspect fader , does the fader value pop up on the OLED as if you were touching the fader ?
I can confirm that this happens. Fader 9 on my S3 randomly fails and starts working again. I just ran thru all of the paces of the S3 setup fader mode after it continuously failed on me and wouldn't reset. It now seems to be working and when i tapped around the fader the db value popped up as you said.
I've been debating on ordering a new fader but from all I've read, I wasn't sure if it was software or hardware related. I'm running Econ 3.6 and the updated firmware. Do you have any idea what it could be?
Old 04-19-2017, 04:08 AM
Narafi Narafi is offline
I was able to test it on our S3 yesterday, and as luck would have it, no faders went down all the time it was on.
I decided to do the tapping test anyway, and the device didn't react (nothing changed on the OLED).
So at least, it doesn't do it when the faders are "healthy", but I'll try it again if a fader should go down.
Old 04-22-2017, 08:09 AM
The Saxplayer The Saxplayer is offline
Well after my "tap-dance" and an upgrade to Eucon 3.6 all seems well for the moment. I will repost should my problems reoccur.
Thanks so far!
Georges
Thanks very much
Georges
The Saxplayer
Old 04-24-2017, 05:04 AM
The problem with Fader3 making random adjustments has returned....
Thanks very much
Georges
The Saxplayer
Old 04-24-2017, 06:59 AM
Had fader 4 failing again. I succeeded to reset the machine without having an immediate fail, and proceeded to do the tap test... Nothing, OLED doesn't budge.
  #16
Old 04-24-2017, 10:56 PM
Tobias Eichelberg Tobias Eichelberg is offline
For those that have replaced a fader on the S3 - can you post the part you used?
Was it this one (that's the fader used by the Artist series controllers):
https://www.conrad.de/de/motor-fader...170425055453:s
  #17
Old 05-27-2017, 07:19 AM
As far as I am concerned....
I will replace faulty fader with a new one.
It is a actually simple.
However: 63€ not 23€ when ordered at Avid dealer in Yurp.
Darn, if I only I knew for sure it is hardware related (then I would still curse about poor build quality, but at least I knew)
Cheers
Georges
Thanks very much
Georges
The Saxplayer
  #18
Old 06-06-2017, 12:44 PM
And now there are more faders at once that behave erratically.
What the... ??
Thanks very much
Georges
The Saxplayer
  #19
Old 06-06-2017, 05:43 PM
EddieJones's Avatar
EddieJones EddieJones is online now
No this is the S3 Fader http://www.mouser.com/ProductDetail/...%2FON8sg%3D%3D
  #20
Old 07-15-2017, 01:15 AM
Well for the price they are asking I can go the official route via my dealer....
Thanks very much
Georges
The Saxplayer
Avid Artist Community "Visualforce" error Airehnr66 General Discussion 0 04-04-2016 04:58 PM
Avid Profile Fader Bay Circuit Boards failing [email protected] VENUE Live Sound Systems 1 12-13-2015 11:07 PM
Avid/Digidesign Pro Control 16 Faders (Main Unit + 8 faders pack) Eduardo Apolonia Buy & Sell 3 11-24-2015 09:56 PM
What's the fix for a session that throws this message? albee1952 Pro Tools 10 2 06-05-2014 11:09 AM
Faders failing on some sessions lyoung1101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2007 11:55 AM
