Re: How to Midi key.
My keyboard model is the one named above. In pro tools i use the ''Mini Grand'' right now, but have been trying pretty much all with the same result.
In my video I show that the output of the Instrument section needs to be mapped to the instrument that you have on that insert. Have you done that? If so, when that track is record enabled, do you see the meter in the instrument window jump?
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course Pro Tools HDX 2023.9 Mac Pro 7,1 3.2 GHz 16-Core Xeon W 160 GB RAM macOS 11.7.4 Noisebox Studios -Utah Recording Studio |
Another thought. Is the output of the instrument tack (I/O) track view greyed out? Or the track lane greyed out?
Is that under I/O?
No, my windows do not jump when i press the keys. I can press the keys with my mouse inside Mini grand and both the windows jump and sound is played. |
You did mention that you installed drivers. Did you install the latest ones from the manufacturer website?
#16
Also, the instrument routing isn't under I/O. It is "Instrument" in the track view.
#17
I only installed the one, which came with the keyboard. A disc.
To return to your question before, under I/O my ''Input'' says ''no input'' and my ''Output'' says ''Main Out L/R (Stereo) -> Analog Output 1-2'' |
#18
From what you have explained, I assume it is one of two things.
1. The "Instrument" view's output is not routed to the instrument on the track. (1:58 in my video) Or 2. The driver is bad and you should see if there is a new one from the manufacturer's website to download and install.
#19
Hmm. Under Instrument i have the first box set to ''All'', the second box set to my keyboard, in this case Impact LX49.
My Inserts A-E are Mini Grand. My Input and output is described as before. Is this the correct setup? |
#20
How to Midi key.
No. The second box should not go to predefined (where your keyboard is). It should go to the instrument (Mini Grand 1 - channel-1)
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input | yellow | Eleven Rack | 1 | 05-04-2012 03:33 PM |
003 midi ports not there in midi studio setup? Unable to record midi now? | TREBLEBLEED | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 12-22-2009 12:06 AM |
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 | Michaeldante | MIDI | 3 | 03-27-2009 05:42 PM |
USB midi vs. din midi-(the old style midi connector) | Ling | Pro Tools M-Powered (Win) | 1 | 02-19-2009 02:15 PM |
Assigning MIDI sounds to MIDI controller and playing sounds with MIDI | lalalandguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-02-2009 12:52 PM |
