ADR with Video Satellite
Hiya,
Is there any software to generate streamers etc inside Avid Media Composer? Cheers Matt |
Re: ADR with Video Satellite
No - but if you are using desktop video window on your MC then EdiPrompt from Sounds In Syncs would be your friend, failing that it's the usual composite streamers from Colin Broad
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
There is no software solution for this that I know of -however you can get a graphic made to overlay as a streamer/ wipe -once it is set up to add a steamer in correct loctaion it is relatvly simple, locate to 5sec before cue and hit 'V' to paste it in place.
http://www.bhphotovideo.com/c/produc...Video_Cue.html http://www.endpointonline.com/products/styled/vm15.html |
"Video Satellite Option 1.0 - Authorization Error" - without Video Satellite | Matts | macOS | 7 | 06-29-2011 08:32 AM |
Confused with Video Satellite LE /Satellite Link | kd_special | Post - Surround - Video | 0 | 12-02-2010 08:42 AM |
Video Satellite and Audio Satellite - Sorry, I´m confused NOW! | Mubeau | Post - Surround - Video | 6 | 05-03-2010 02:13 PM |
Video Satellite LE - Enable Satellite Mode is greyed out? | Erik Olsson | Post - Surround - Video | 6 | 01-11-2010 09:16 AM |
Video Satellite LE and Satellite Link !!!!!! | dr sound | Post - Surround - Video | 10 | 10-09-2008 07:11 PM |
