Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 08-04-2013, 04:23 PM
drumzalicious drumzalicious is offline
Default Mbox 3 Flashing lights
Was just in the middle of doing some recording when my Mbox suddenly disconnected from the computer and appeared to be starting itself over. Of course I had to shut down Pro Tools because it became disconnected in the middle of the session.
The Mbox however kept flashing its lights in order like it was starting up only to shut off and do it again kind of like a boot loop.
Things I've tried:
Disconnecting Mbox and reconnecting
Changing USB Ports
Changing USB Cable
Uninstall Drivers, Restart, Re-Install Drivers. (1.1.4)
At this point I don't know anything else to do. When opening the Mbox control panel it says "Hardware not connected" and the Mbox continues its little light show.
Any help would be appreciated.
Old 08-06-2013, 02:05 AM
JazzyJ JazzyJ is offline
Default Re: Mbox 3 Flashing lights
1) Try the Mbox 3 on a different PC/Mac if possible (will need to download drivers) in order to discern whether it's a hardware or software problem. If it doesn't work on another computer (with the correct drivers) then the problem lies with the Mbox3
2) If it's software - Try reinstalling Pro Tools?
3) If it's software - Check to download most recent drivers
4) If it's hardware - You could try 're-flashing' the firmware?
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 06-01-2014, 02:20 AM
Sepand Sepand is offline
Hi there guys , i have the same problem with my Mbox 3 and i am using macbook pro, quite old one. and i was using it and suddenly it disconnected and started the light show. pleaaasssseee if you have found the answer of the problem let me know. PLEASE.
Old 06-01-2014, 02:23 AM
hi there . i see that you had the same problem as me a long time ago. can you please help me out. i've tried uninstall and re installing my drivers, i bought a powered USB hub , and i've tried it with my friend's computers and it worked. it's just not working with my own laptop. do you think its a problem with my laptop or...? Please help me out.
MBox 3 Lights flashing augster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 11-18-2018 06:52 PM
Mbox Pro - Loss of connection and flashing lights Marcio FireWire & USB Audio Interfaces (Win) 2 05-03-2013 10:37 AM
Mbox 3g Flashing lights sequence osx 10.7.5 beatsamillion FireWire & USB Audio Interfaces (Mac) 3 04-25-2013 05:52 AM
Flashing lights Mbox Sid0 FireWire & USB Audio Interfaces (Win) 11 04-23-2013 03:58 PM
Mbox 3 Flashing Lights. Sid0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-17-2011 08:03 AM
