Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 06-09-2012, 06:48 AM
John_Toolbox's Avatar
John_Toolbox John_Toolbox is offline
Default can someone help identify this acoustic "sound deadening board" material?
I acquired some of this "sound deadening board", it was used to insulate an office from a noisy shop. The boards are 2" thick, and made from a fibery type material. Very rigid and very heavy. I'm trying to figure out what this stuff is called so I can do some research on what the best use of it is for my studio.
Does anyone know the name of this product, or anything about it's performance?
Here are some pics of what it looks like:
http://pic100.picturetrail.com/VOL10.../402960571.jpg
http://pic100.picturetrail.com/VOL10.../402960569.jpg
- John
If a MIDI event triggers a sample of a tree falling and there's no one there to hear it, does it make a sound?
Old 06-09-2012, 05:12 PM
Emcha_audio's Avatar
Default Re: can someone help identify this acoustic "sound deadening board" material?
I've been looking through the company's I know of, and none seems to be using this kind of product, so I'm at a loss. Sorry.
Manny.
Wave-T.com
Old 06-09-2012, 05:24 PM
necjamc necjamc is offline
Default
That looks like the stuff they use in school auditoriums. Couldn't tell you what it's called. But I know I've seen it.
Old 06-09-2012, 05:33 PM
Jay_uk Jay_uk is offline
It looks like compressed straw, so thats what i Googled... result is.
it could be this Stramit ... or ... Straw board, straw mixed with cement and used for flat roofs/decking.
http://epdm-rubber-roofing.co.uk/201...ing-osb-v-ply/
Old 06-09-2012, 06:49 PM
Jay UK saves the day! This is exactly what I needed to know. This stuff will be perfect for what I intend to use it for, not only is it designed as an acoustic barrier, it also apparently has an R value of 12, so it will solve both the problem of rain/plane noise and also add some much needed insulation to a currently underinsulated roof.
Interesting reading about how it's made, there is no glue, it's just heated up straw, and the resins in the straw are what bond it together.
- John
Old 06-10-2012, 08:14 AM
It looks an interesting product, hope it works out for you John.
Old 06-10-2012, 06:41 PM
So far, with only 1/4 of the ceiling, and one window covered ,and no sealant of any kind, I have reduced the ambient noise in the room by 10db! (there are 2 central ac units near that window) Very excited to see how it works out once it's all installed.
I did some more reading, the R value is somewhat questionable. Apparently the strawmit brand is advertised to be R12, however some other sites refer to strawboard being R3 or R6... But not specific if they mean R3 per inch, making a 2 inch panel R6, or if they really mean R6 per inch, which would explain the strawmit being advertised as R12 for a 2 inch board. Or maybe strawmit is special. No idea what manufacturer made the stuff I have, it's not marked anywhere that I can see, one side has been painted blue, but I'm pretty sure that was from the previous installation.
This stuff is heavy as hell, once I get the rest of the pieces for the ceiling cut I will probably rent a drywall lift to install them.
- John
Old 06-10-2012, 07:03 PM
Okay..sounds promising.
Where does the fire retardant spec come in, if its just heated up ?
I have not read the spec but iirc, i saw somewhere that cement was involved.. thought thats what made it heavy.
Old 06-11-2012, 04:39 AM
It has a 1 hour fire rating... Meaning it will eventually get burninated, but will slow down the spread of the fire.The article you linked to suggests it is mixed with cement, however all of the other ones I've read suggest that the "glue" is the resins that are in the straw.
When I cut it there are not any funny smells like you get from cutting osb or plywood, which seems to support the idea that it doesn't use any chemical glues.
- John
Video "On-board" or "Satellite" Kuba Pietrzak Post - Surround - Video 13 11-12-2013 12:00 PM
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
How do you get a "Haunted" or "ghostly" sound yijvapar Virtual Instruments 9 08-03-2009 07:04 PM
Quick question on the "Identify beat" option jonslaten 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-07-2009 05:47 PM
