Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 11-12-2011, 04:49 PM
Sid0 Sid0 is offline
Angry Flashing lights Mbox
I have been using my Mbox 3rd gen. fine up to now on both of my laptops and just today my Mbox can't make a connection with my laptop. does anyone know why?
Old 12-05-2011, 08:37 PM
AyanSanyal AyanSanyal is offline
Default Re: Flashing lights Mbox
Hi. having the same problem!
iMac 2.5Ghz Intel Core i5
OS 10.6.6
Mbox 3
Protools 8.0.4
I know its a USB power issue but I don't know how to fix it on a mac
Old 01-09-2013, 07:33 PM
groversi groversi is offline
Hello, guys, did you fix this issue, I am having it now.
Regards
Giancarlo
Old 02-25-2013, 09:00 PM
trenchferret trenchferret is offline
Ok... This is really annoying. This past weekend, my mbox 3rd generation began this flashing chasing lights thing and after installing, uninstalling, and reinstalling all the drivers and drivers updates, it still didn't work. Then, suddenly, after a couple days and after doing nothing, it just started working again for no reason at all! Then... It stopped. Does anybody have any idea what's going on with this fickle device?
Old 02-25-2013, 09:06 PM
sunburst79 sunburst79 is offline
Have you disabled power saving on your USB root hubs?
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 02-26-2013, 06:25 AM
I have a MacBook Pro. How would I do this? Do you think it would help? I have seen several people in duc mentioning that they have spoken to a mythical Avid rep over the phone but every time I call, I'm screened out due to not having an Avid support code. Is there any way to just consult with a rep and bypass that thing?
Thanks!
Old 04-21-2013, 01:42 PM
Default MBox 3rd Gen. Flashing Lights Win.7
I was using my MBox yesterday and in the middle of my session, my Mbox crashed. All I see on my Mbox are flashing lights. I have tried the following:
1) Unplugged the Mbox and connected it to a different usb port & a different computer. MBox still flashes on a different computer.
2) I uninstalled and reinstalled my USB ports
3) Uninstalled and reinstalled pro tools and MBox drivers.
4) Used a powered USB hub
I was unable to get it to work. Can someone PLEASE help me
I am running Pro Tools 8 LE on Windows 7
Old 04-21-2013, 07:57 PM
beatsamillion's Avatar
beatsamillion beatsamillion is offline
ok im having the same problem as you guys now Ive been exchanging emails back and forth with avid reps and this is what i've concluded
because this was a new machine im using and its never worked on it they were quick to say its a hardware issue and had to send it in for repair
BUT
im using a macbook pro running OSx 10.7.5 and when i uninstalled all the drivers and just plugged the mbox in i get the sequence of lights again -ok
So i tried it on a i7 mackbook pro running OSX 10.8 with drivers installed then driver uninstalled and got the same thing sequence of light again SSSSOOOOOOO
I then got my hands on a old style MacBook (not Pro white hard case) running 10.6.8 what the mbox 3g was built for plugged it in and the sequence happened but after one cycle the solid power blue light came on ....soooo i installed the drivers and BAM it works great so we can rule out hardware issue
I tried the power hub that didnt work ether
and i just read somewhere it could be the OS ur running 32bit verses 64 bit?
So its only safe to Assume Im having a compatibility issue?
Old 04-21-2013, 08:18 PM
In my case, I don't think its system compatibility. I have been using my MBox 3rd gen for 3 years on this same laptop. How did you get in contact with Avid reps? I can't seem to get in contact with them
Old 04-21-2013, 08:38 PM
and i also have mbox 2 mini drivers installed does that affect it as well?
MBox 3 Lights flashing augster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 34 11-18-2018 06:52 PM
Mbox 3 Flashing lights drumzalicious FireWire & USB Audio Interfaces (Mac) 3 06-01-2014 02:23 AM
Mbox Pro - Loss of connection and flashing lights Marcio FireWire & USB Audio Interfaces (Win) 2 05-03-2013 10:37 AM
Mbox 3g Flashing lights sequence osx 10.7.5 beatsamillion FireWire & USB Audio Interfaces (Mac) 3 04-25-2013 05:52 AM
Mbox 3 Flashing Lights. Sid0 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-17-2011 08:03 AM
