Old 01-30-2009, 09:45 AM
Jsalam112 Jsalam112 is offline
Default All lights flashing on my D-Command
The D Command is functioning. However, all lights and scribbles strips are flashing in less than 1 second intervals.
Tried the reset with no change.
Is there a PSU for the leds that could have gown bad?
Old 01-30-2009, 10:54 AM
Chris Lambrechts's Avatar
Chris Lambrechts Chris Lambrechts is offline
Default Re: All lights flashing on my D-Command
That would be a possible scenario yes.
You should contact tech support and go through troubleshooting with them.
In preparation of that make sure you have the Serial Number of the Unit(s) at hand and.
Worthwhile trying is :
Reset Firmware : press the <Select / Solo / mute> switches simultaneously while powering up the unit. Go into the peripherals menu and press OK. This should bring up the message to upgrade the firmware.
Out of curiosity ... is there something that may have been the cause of this ? Did this happen after something specific ?
Also, in the utility pages, prefs, there's brightness and contrast settings. Crank them up and down and reset them to the values they were at. Does this change anything ?
All these are 'wild shots' but worth a try before contacting tech support imo.
You should be able to find the Support contact number for your area on the digi website : Support > contact.
Chris
Chris Lambrechts
Applications Specialist- Live Sound
Old 02-03-2009, 01:02 PM
acacia acacia is offline
Hey Jsalam112, Did you find the problem?
Luke Rohwer
Acacia Recording & Production
www.acaciarecording.com
Luker[at]acaciarecording[dot]com
Studio 301-703-0035
Old 02-05-2009, 10:22 AM
amorlando amorlando is offline
exactly. we have many dcommands and this is what happens when the switch mode power supplies fail. as the suppply ramps up to operate, the current draw from the LEDS puts the supply into protection and recycles the power. about every 1 second exactly. the good thing is that these control surfaces use a seperate supply for LED, Logic and motors so although the lights are crazy, it will still control the software and the faders will still move.
Studio Troll
Old 01-26-2017, 04:18 PM
Drew Mazurek's Avatar
Just thought I'd share what happened to me the other day......
Came back from NAMM to find my D Command exhibiting this LED blinking thing..... contacted Avid, tech instantly knew what the issue was. Bad LED power supply. They overnighted a new PSU for $268 including shipping-not too bad considering how specialized this part is and especially compared to Apogee that wants $530 (+$110 for expedited service) to fix my Symphony I/O!!!
Really great customer service experience for sure!!!
www.drewmazurek.com
Old 01-26-2017, 04:36 PM
YYR123's Avatar
YYR123 YYR123 is offline
Got a pic of the Pwr supply for the crowd?
Seriously that way we know what it looks like.
And will you put it in?
I had my Pro Control apart the first night I got it....but I didn't want to get into any problems with this DCmnd
Daniel
Old 01-26-2017, 04:48 PM
It's already in, it was super easy. Here's the old one.
www.drewmazurek.com
Old 01-26-2017, 07:13 PM
YYR123's Avatar
Cool thanks
Daniel
Old 01-28-2017, 09:34 PM
Barry Johns Barry Johns is offline
Great news, thanks for sharing. Hope I never have to de with it, but if I do, I now have more troubleshooting knowledge than I had before!!!
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Old 06-02-2017, 12:15 PM
WantedSP WantedSP is offline
How did you install this?
Mbox 3 Flashing lights drumzalicious FireWire & USB Audio Interfaces (Mac) 3 06-01-2014 02:23 AM
Flashing lights Mbox Sid0 FireWire & USB Audio Interfaces (Win) 11 04-23-2013 03:58 PM
flashing lights? stainless ICON & C|24 1 05-31-2006 02:49 PM
Flashing lights on 002, anyone else? Jak 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-09-2003 09:46 PM
What's with the flashing lights? ngisedigid Pro Tools TDM Systems (Mac) 10 02-28-2002 01:06 AM
