digi 002 just blown for no reason?
Hi, can anyone help me with a suggestion, recommendation, fix – the digi 002 box (about 12months old) I am using to record with –has just blown its power for no reason. Is this a digi design fix only problem. Dose anyone know if they have fuse inside that may have blown? There was a little bang, then nothing, it wasn’t even doing anything at the time.
Would love any help. |
Re: digi 002 just blown for no reason?
Not sure if it's the same problem but I had similar a year ago. I did a search and would up opening the top and messing with one of the ribbon cables, cleaning it, exercising it and the power came back, no problems since...Search on and Good luck! Always call digi if you can't handle it.
Betsy Thomson |
If there was a bang, check inide for fuse too but if a fuse blew that means somethng is not right.
Betsy Thomson |
Thanks Betsy. So far its still not working. Is you’re a desk box or a rack box. Mine is a rack?
I really would love anymore ideas out there? |
Could be the power harness. Contact Digi to get a replacement sent to you. They've had a whole lot of problems with the original power harnesses.
Sounds like the power harness. This happened to me and called tech support. They confirmed it was the harness and sent me a new one for free. It's pretty easy to install and it fixed the problem. It's been running great since. Call tech support they'll help you through this.
iMac 27" 3.4 GHz Intel Core i7 Pro Tools 10.3.10, Digi 002, Octopre w/Adat light pipe, Glyph GT052 |
Blown Fuse Digi 002 Power supply | liamMo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-08-2013 08:51 AM |
192 I/O Just blown up!!! | Gallellao | Pro Tools TDM Systems (Mac) | 17 | 08-29-2010 12:12 PM |
Blown Headphone Amp? | agauchede | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-27-2010 07:24 AM |
Blown Output? | rucontent | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-06-2009 07:06 AM |
DIGI 02r power supply blown again | supafuzz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-06-2007 05:42 PM |
