monitor hiss
hello, i just bought a new pair of KRK v6 series 2 and i noticed a very low hiss from the both speakers. the hiss is not loud at all but i can notice it when nothing is playing. is there something wrong? do all speakers do this? am i just worried for nothing? i'm going from my 001 into my mackie to my speakers using 1/4 inch plugs (tip sleeve). thanks
Re: monitor hiss
I had the same problem with mine. Write them an email or give them a call, it's a known issue. They told me there was a bad batch of V series that went out to stores. They sent me a new pair a few days later, great customer service.
www.krksys.com
www.myspace.com/krou |
Re: monitor hiss
wow, how bad was it in your speakers? i mean i could just be a little jumpy and i don't want to send back a perfectly good set of speakers. the hiss is hardly audible, but there.
Re: monitor hiss
If you're monitoring digital audio from the 001, try using balanced cables from the 001 to the monitor speakers. If you're monitoring the analogue audio-out from the Mac via analogue inputs 3-4 on the 001, balanced monitor cables alone may not be enough, since you'll get some noise from the unbalanced cable between the Mac and the 001. and the only fix I know of for that is a ground-loop isolation transformer. If you're monitoring digital audio via the 001, the speakers ought to be silent when nothing is playing, but you should be using balanced cables.
Dual 2.0 G5, 10.4.6, PTLE 7.1, 002R |
Re: monitor hiss
The hiss I had wasn't related to audio cables whatsoever.
Just plug in the speaker and the hiss was there, not very loud but audible enough to be annoying. It also wasn't a power outlet issue, it was the monitors, plain and simple, and they know it, and they'll send you a new pair.
Re: monitor hiss
so i disconnected the audio cables and still hear that small hiss, this is what your talking about right? So should i return them to guitar center, or call up KRK?
Re: monitor hiss
Yes, that's the same problem.
I would at least tell GC about it first, by now I'm sure they're aware of the issue, perhaps they can do an in-house trade. You'll be quite happy with your new pair, they're awesome monitors!
Re: monitor hiss
thanks man, so yours are good now? from what i've played on them i love them (just not that hiss). a big step up from my tr5s
Re: monitor hiss
888|24 Monitor Hiss | HSLand | Pro Tools TDM Systems (Mac) | 9 | 03-06-2014 07:10 AM |
mbox 3 pro monitor hiss | capellino | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 01-24-2012 08:08 AM |
Control24 Intermittent Hiss in Monitor | Rwave | ICON & C|24 | 0 | 07-26-2010 07:57 AM |
Monitor Hiss | brothertony | Pro Tools M-Powered (Mac) | 5 | 10-18-2009 06:45 PM |
Monitor squeeks and hiss | millicent frndly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-10-2005 07:34 AM |
