Old 01-29-2004, 04:48 PM
betsy betsy is offline
Default 002 Monitoring TRS & RCA w/ 2 sets of monitors?
I'm buying the 002R tomorrow.
From reading the specs on the 002>>>>>>> "Outputs 1 & 2 mirrored on 1/4" TRS monitor output (with dedicated volume control)
and RCA-based -10 dBV fixed output"
I'm taking it that I will be able to use my main Balanced Main Monitors with the TRS (volume control on the 002) and use the fixed RCA for my secondary speakers which has it's own power amp with separate volume control - Correct?
Thanks Guys!
Betsy Thomson
Old 01-29-2004, 07:04 PM
where02190 where02190 is offline
Default Re: 002 Monitoring TRS & RCA w/ 2 sets of monitors
the RCa is -10dbv, provided the input sensitivity of your amp is, it'll work fine.
Old 01-29-2004, 08:21 PM
Very helpful. Thanks!
Betsy Thomson
Can I use two sets of monitors on 003? goga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 04-24-2013 08:15 PM
Switching between two sets of monitors on Omni ? chrisdee Pro Tools HDX & HD Native Systems (Win) 13 08-12-2012 11:44 AM
2 sets of Monitors, 1 sub... ripekeai Pro Tools 9 6 07-04-2011 11:33 AM
Setting up 2 sets of monitors with Digi001 James Blomquist 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 05-30-2003 08:43 AM
More than two sets of monitors Nashville Bass ProControl, Control|24, Command|8 10 04-09-2003 09:04 AM
