What is the beginning and end of a daisy chain...
hey everyone
so i'm getting pretty confused about the whole "daisy-chain" concept. i understand what is is, but what's the general rule about what's FIRST in the chain? for example, i have a digi002 i have a pc that has only ONE firewire port i keep getting mixed messages about where to put my external hard drive the manual says to connect an external HD into the back of the digi002 is this not the BEST way? some people say to connect the hard drive to the comp first, then connect the 002 to the back of the hard drive. what's the right way to do this?? also, what is the beginning/end of this chain? would the computer be last in the chain? thanx everyone |
Re: What is the beginning and end of a daisy chain...
Computer to HD, HD to rack...
MYSPACE ON'EIM LAUTEN MICS & ME DA'TUBE ON'EIM 'IS TAMARA HOME' NO, SHE'S WITH HOBO KEY '' (that dopey green thing) ('we' must start using pronouns) |
Administrator Avid Pro Audio Community |
hhmmm
ok, so the computer is the first in the chain. i guess i'm thinking the total opposite. i mean.... data is going INTO the digi002 and gets stored into external hard drive or hard drive of the computer (seeing that it is possible to record tracks on the comp's hard drive), right? so wouldn't the computer be the LAST in the chain?? i just want to make sure i'm grasping the whole signal flow concept |
of course! i'm not saying i don't believe him/her, it's just that i thought i had a good understanding of signal flow... and since the computer is what's getting input LAST (seeing that audio goes INTO the digi002, then gets saved on the computer's hard drive), one would assume that the last thing in the chain would be the comp, right? i mean... is there something wrong with the way i'm thinking about this? if so, i'd like to know so that i won't be wrong i'm the type of person that wants to understand how things work, u know? so if someone tells me that the FIRST thing in the chain is the comp, i'd want to understand why that is |
Oh, Ok
thanx for the quick reply it's much appreciated however, i'm still getting a bit confused for example, let's just stay that all we got is a computer and digi002...no external hard drive, and we are going to track to the computer wouldn't the chain be like this: digi002 > computer, rather than computer > digi002? also, i just realized that my external hard drive has only one firewire400 port (and 2 firewire800 ports), so i can't hook up my digi002 to the back of the external since it's being taken up by the computer. in this situation, how should my daisy chanin be then?? thanx so much for ure help i'm a big stickler for having a optimal setup, so all ure help is highly appreciated thanx! |
If I remember right he said (quoted from my memory), Quote:
MBox 2 Pro connected to motherboard 4 pin firewire port Dell Inspiron 9300 laptop 2.0 gHz Pentium M 2 gB ram Lacie Rugged 5400 rpm firewire 800 on Siig Cardbus adapter Roland 700SX stage piano Studio Projects C3 mics Melodyne Plugin Dual Boot: PTLE 8.0.1 on Windows 7 Enterprise 32 bit PTLE 8.0.1 on XP Media Center SP3 |
Try thinking of the firewire cable as a two way street. The information goes in both directions, not from point A to point B.
Cheers,
Daisy chain...should I? | Sam C | macOS | 5 | 12-01-2011 08:16 PM |
How to daisy chain??? | mutley | Storage Subsystems | 1 | 09-20-2009 07:17 PM |
Can't daisy chain HD with 003!!! Pls Help!!! | sureno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-25-2009 05:20 PM |
Daisy chain? | mdulation | Storage Subsystems | 2 | 10-29-2006 03:39 PM |
studio setup - midi - to "daisy chain" or not to daisy chain - do I want a multiport | Joseph Anderson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 01-24-2002 02:45 PM |
