Go Back   Avid Pro Audio Community > Other Products > Storage Subsystems
Old 01-08-2012, 08:56 AM
sponstage sponstage is offline
Default Internal Mac HD
Hi guys,
I'm running PT 10 on a macbook pro 2.66 with an internal 320gb hd 5400rpm.
I also use an Mbox pro with an external hd 7200rpm.
I'd like to change the internal HD and buy a 7200 rpm one. Which model should I look for? 16mb chache?
Also, it is good to partition the internal HD?
Thank yo very much in advance!
Old 01-08-2012, 09:42 AM
CME CME is offline
Default
Recording to the system drive is unsupported and not recommended either. A secondary drive is always the best solution. Also partitioning will only make things worse. As the drive heads have twice as much to do. So if want a second drive look into putting one in your optical bay. That's what I've done and love it. :)
Dell T5810. Harrison Mixbus 32C. Haven't used PT since 2015 and never been happier.
Old 01-08-2012, 12:36 PM
Default Re: Internal Mac HD
Sure, I use the external hd for sample and recording. I just want to change my 5400rpm internal drive to a 7200 rpm one.
So make a partition of the internal one is not good?
Old 01-08-2012, 02:01 PM
CME CME is offline
Default
Partitioning is def not a good idea for recording and i thought that is what you were thinking. And it really doesn't have a lot of benefits for most things. One exception being partitioning the HD for two OS's and then it's a necessity and not a performance thing. So if you are looking for performance I'd look into the Seagate Momentus XT hybrid drives. Partition only if necessary IMO.
Old 01-08-2012, 03:48 PM
Cool, thank you!
Old 04-20-2012, 06:52 AM
HorseFD HorseFD is offline
Does your Macbook have Firewire? I'm pretty sure an external firewire drive is the best way to go.
MC Pro with Internal SSD lukesytan System 5 8 05-14-2013 09:22 AM
I've Never Had To Do This, Is It Internal? Bloux 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-21-2002 11:41 PM
Internal HD G-Dog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-03-2000 10:03 AM
QT from internal G4 ATA tombi Pro Tools TDM Systems (Mac) 2 06-20-2000 10:48 PM
internal hd for g4? fiddle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-02-2000 04:57 PM
