Old 10-12-2020, 04:33 PM
pasanta pasanta is offline
Default Artist Control no longer connects
I have an artist control and mix. Both have been fine. No changes to anything. All latest versions. EuContol 20.6.1.3 . OSX 10.13.6 MacPro. Firmware says current, albeit, for as long as it will stay connected to check. However, it would've been updated every time the mix was, and it is current.
The mix still connects normally. The control shows up at all in EuControl settings window for about 30 secs to a minute, before dropping the connections with a dialog box about connection issues. Sometimes it doesn't show at all. I have switched all cabling from the mix to the control, no change. Even the power supply. I've taken it off the ethernet hub and went directly to the Mac, no change. And I've tried setting a static IP, no change. And I've tried uninstalling and reinstalling EuControl.......even tried going back to a previous version.
Anything left to try......or does it need servicing?
Old 10-13-2020, 08:57 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Default Re: Artist Control no longer connects
I'm sorry it does sound like the hardware has an issue. What happens on the display when it connect and disconnects ?
Old 10-13-2020, 09:48 AM
if it connects at all, the screen just freezes however it was last. otherwise, it just never displays anything but the big AVID logo
Old 10-13-2020, 11:58 AM
MoPro's Avatar
MoPro MoPro is offline
Originally Posted by pasanta View Post
I have an artist control and mix...
The mix still connects normally. The control shows up at all in EuControl settings window for about 30 secs to a minute, before dropping the connections...
Anything left to try...or does it need servicing?
Have you tried connecting just the Control by itself to the MAC?
It does sound like you might have an intermittency during the handshake process... maybe check the Ethernet jack for looseness, or bent wire in the jack itself. Also check the power supply, jack, cord, etc.
Physically pick the unit up and gently shake the unit... listening for something loose rattling inside the unit. A broken solder bead, or loose screw can reek havoc in the wrong place.
I know what I suggested is a stretch, but you might as well check everything you can before you send it to have it serviced, and the more info you give the service tech may help them toward a solution.
Computer Asus P9X79 Deluxe | Intel i7 3930k | 32 Gig Ram | Intel 520 SSD's | 2T Caviar Black
Software Win 7 Ultimate (64bit) | Cubase Pro 9.5.41 (64bit) | WaveLab 9.5.25 (64bit) | HALion 6 (64bit)
Hardware RME FireFace's UFX / 800 | MOTU MTP AV USB | Avid Artist Series: Control, Mix, and Transport | EuControl ver. 18.3
Old 10-13-2020, 03:26 PM
Yes to all that I'm afraid. And the same cable that works with the Mix, both on the hub and directly to the Mac, doesn't on the Control. I've checked the ethernet jack and nothing seems loose or broken. The units just sit on my desk.......worked Friday. Came Monday and the Control wouldn't connect. No one there on between and power totally off.
Old 11-30-2020, 02:24 PM
I'm returning to this issue again. I just spoke with Sweetwater where I bought it and they wanted me to call Avid and arrange for service, as Sweetwater no longer services these. Of course, calling Avid just gets a switchboard, I select proper options and then get disconnected every time. I can't seem to wade thru any online process without buying a service ticket or something.
So how do you get a pice of Avid hardware serviced?
Old 11-30-2020, 04:48 PM
EddieJones's Avatar
The Artist Control is end of support. Try these guys: https://advancedmusical.com/
Old 11-30-2020, 07:12 PM
Pathetic. But typical Avid.
Old 12-01-2020, 03:07 AM
MoPro's Avatar
I know it sounds counterintuitive, but try connecting the Artist Devices via an unmanaged switch instead of a hub...
Several users in the past that have had connection issues have had success connecting the devices this way. My connection is via an unmanaged switch, and I have never had connection dropping issues... I don't know why... It just works! Not a router... just a switch!
I would definitely give it a shot before sending it in to have it serviced. I use a D-Link DGS-1005G, 5 port Gigabit switch. Never a hiccup... promise!
Al
Old 03-28-2021, 07:42 AM
DominikS DominikS is offline
Hi Pasanta,
I have the exact same story happening here. Same setup, same symptoms. So I wonder, could you ever got the issue resolved?
Since we know that the Artist Control is end of life, I assume I have to except that it just died...
Thanks for your insight
Dominik
EuControl 3.6 crashing when Artist Mix connects [email protected] Artist Series 10 06-02-2017 01:32 PM
Artist Mix's Ethernet connects to a Router? Rockman413 Artist Series 1 08-28-2016 11:45 AM
Artist Mix No Longer Working in OS X 10.8.4 Chingy Artist Series 6 07-03-2013 04:46 PM
Just Purchased NI Maschine Now my Controller No Longer Connects tdtj77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-05-2012 01:42 PM
Mbox connects then unconnects then connects and so on..... Salew 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-31-2008 06:18 PM
