Old 07-04-2020, 06:29 PM
groovebrother groovebrother is offline
Default (SOLVED) HD Native Core Card and PE6R4-i Magma Chassis Compatibility
Hi all, i could read that the core card should be installed right after video card. Actually my PE6R4 chassis is installed in slot 4 . I would like to switch back & forth between PTHD10 (TDM) wich remains my primary work station & PTHD 11 and later. Is there any known issues having both in a mac pro ?
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Old 07-05-2020, 06:07 AM
JFreak's Avatar
JFreak JFreak is offline
Default Re: HD Native Core Card and PE6R4-i Magma Chassis Compatibility
AFAIK, you cannot have both TDM and HDN installed at the same time.
Janne
Old 07-05-2020, 03:14 PM
Aïe ... even i boot on different osx versions ?
Besides it is not an TDM card directly installed in the MP but a Magma card so i was hoping this would do the trick.
also i was hoping that if the chassis is turned off, the HD native would work.
Anyway i should get my HD native card this week so i'll let you know how it went ... crossing fingers
My soundcloud page
Old 07-05-2020, 05:04 PM
JFreak's Avatar
Even if you have TDM on expansion chassis your host chassis would have HDN installed, so for the information I have it will not work. Easiest would be swapping between HDN card and Magma card on the same slot.
Janne
Old 07-05-2020, 05:06 PM
JFreak's Avatar
That would work, but when you turn on the chassis and your system sees HDN first and then TDM cards on expansion chassis it gets confused.
Janne
Old 07-12-2020, 04:21 PM
Works at perfection booting on 10.11 with all cards in the mac set properly.
When booting on Mavericks and getting back to TDM : no problems at all
That's really awsome !
My soundcloud page
Old 08-23-2020, 05:01 PM
hi all,
just to give an update.
as i said it all worked like a charm till suddenly after quite a lot boots on El Capitan (PT Ultimate) + Moutain Lion HD11 & HD10 (TDM) on Mavericks, i started to have "issues" :
evrytime i went back on the TDM rig, pro tools said the memory had to be ajusted.
Now i am forced to pull out the HD natve to get rid of this message and clean all prefs in PTHD10 to get it work as before.
JFreak, the incompatibilities you were talking about are here now.
That's all folks
My soundcloud page
Old 08-24-2020, 03:35 AM
JFreak's Avatar
Maybe you can find another 2nd hand chassis for low price for the HDN, then you only need to swap chassis cable
Janne
Old 08-26-2020, 10:10 AM
indeed : that's an option
that or get me another MP
OFF TOPIC : i have been amazinly suprized to see how low is the latency with waves plugings in native mode.
Native seems now pretty close to dsp rigs.
... now that i have a HD Native, it makes me feel going into HDX ... not funny
My soundcloud page
Old 08-26-2020, 10:52 AM
JFreak's Avatar
I have been amazed how much faster I mix now that I have zero WavesHell installed
Janne
HD Native Card + PE6R4-i Magma Chassis groovebrother macOS 0 05-29-2020 02:10 AM
Magma Chassis w PCI-E & PCI Host Cards, Expansion Cable + Pro Tools HD Core Card Phil Pelissier Buy & Sell 0 07-15-2015 04:49 AM
Accel card compatibility in Magma PE6R4 Straight Shooter Pro Tools TDM Systems (Mac) 10 09-11-2014 01:05 PM
FS: Magma PE6R4 chassis w/ cable and PCIe control card WildHoney Buy & Sell 1 10-06-2013 02:28 PM
AVID HD Native Card with ProTools HD9 Auth and Magma PCIe Chassis - $1500 UnkleMik Buy & Sell 2 06-03-2013 04:14 AM
