Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
  #111
Old 07-12-2020, 05:55 PM
Goombot Goombot is offline
Default Re: First steps with MTRX Studio
Hello again Jeff. Another question. I noticed the other day when I working when I went to the monitor page of my iPad that the speakers were not showing up. All the other tabs in the EuControl app were working fine except the monitor tab. When I looked at the DADMan there was no signal in it. I was working fine and hearing everything fine in ProTools but no meter in the DADMan. I double checked that I was on the Dante Virtual Soundcard and I was. I quit everything then opened the DVSC, the Dante Controller, DADMan, the ProTools and still the same thing. Any idea why that is happening? I'm assuming I'm not seeing any monitoring on the EuControl app because I'm not seeing it in DADMan. Any thoughts? Thank you.
  #112
Old 07-12-2020, 06:36 PM
creativecontrol's Avatar
Greetings,
Certainly if you don’t have signal presence in DADman you are also not going to have it on the Avid Control Monitoring tab interface as well.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #113
Old 07-12-2020, 06:43 PM
Right but any idea why I’m not seeing signal in DADMan if everything is locked. I didn’t change anything.
  #114
Old 07-12-2020, 06:46 PM
So you are monitoring the output of Pro Tools which is using DVS as a playback engine and you have audio but simply no metering in DADman or Avid Control?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #115
Old 07-12-2020, 06:47 PM
Correct. It’s weird.
  #116
Old 07-12-2020, 06:50 PM
Try simply quitting DADman and then re-launch having it auto-load your last monitor profile.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #117
Old 07-13-2020, 12:45 PM
uptheoctave uptheoctave is offline
Hi folks, looking for some input.
I'm about to bite the bullet on either the MTRX Studio or the MTRX.
MTRX Studio is obviously priced better for me and it is a compelling purchase but I don't want to compromise on conversion quality- I want as good or better than I currently have.
I am currently running a Red 16 Line + 2xA16r's plus an X2P, with HDX in a 2019 Mac Pro.
My issue with the Red 16 Line is it isn't sample accurate for inserts.
Otherwise it is excellent.
How is the conversion quality with the Studio vs the MTRX?
Can we 100% confirm that hardware inserts work as expected?
I have a lot of outboard and want to be able to use parallel compression in inserts.
How is the fan noise?
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
  #118
Old 07-13-2020, 12:48 PM
I can't accurately tell you about inserts since I don't use any and I can't tell you about conversion quality expect I can guarantee you that you'd be hard pressed to tell any difference in a blind test. I can tell you that my unit is silent. I don't have it in a rack and maybe that helps but I don't hear it at all.
  #119
Old 07-13-2020, 01:24 PM
Greetings,
If you are looking for the ultimate conversion quality I would highly recommend going with Avid MTRX. The AD and DA converters are simply exceptional. MTRX Studio is also a great sounding box, however for quality and expansion capabilities, MTRX is superior.
Can you use Hardware Inserts? Absolutely. The only additional step required (from an HD IO for example) is to add the (documented) converter delay into the Hardware Insert Delay field in the IO Setup.
For both MTRX and MTRX Studio, if they are racked correctly with space above and below you should never hear the interface.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #120
Old 07-13-2020, 02:43 PM
Thanks both.
Does hardware insert delay sample accuracy also apply to IO over Dante?
James Richmond
Affiliate Links:
MTRX Studio i/o Cheesehead Post - Surround - Video 9 02-21-2021 08:17 AM
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card antonis Buy & Sell 9 04-11-2020 06:47 AM
Still no specs on MTRX Studio Avid? corp Pro Tools | MTRX & MTRX Studio 51 04-02-2020 05:31 PM
MTRX Studio - No AES?! Ryan Young Pro Tools | MTRX & MTRX Studio 23 02-23-2020 02:13 PM
analog console, next steps for my studio badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-28-2003 08:03 AM
