Old 08-10-2020, 11:13 PM
bigbuddy3 bigbuddy3 is offline
Default PT 2018.12 -Plugin wont appear after selecting on insert
HI,
Mac Pro 2009 4,1 8core El Capitan
PT 2018.12. (Tried Both Ultimate and Non HD License)
All of my plugins appear in the dropdown pane and I can select them on an insert. After I select the plugin, it does not appear on the insert. All plugs respond the same.
The odd thing is, if I load a session with plugs, they appear, if i create a new track, plugs wont load.
I reinstalled PT as well as ilok manager, no change
I tried this on a different Mac Pro with same OSX and PT version. that worked fine.
Thanks
Old 08-10-2020, 11:14 PM
Default Re: PT 2018.12 -Plugin wont appear after selecting on insert
I also trashed my prefs,
thanks
Old 08-12-2020, 09:51 PM
Also No Audio Suite Plug ins will initiate...They are all there in the Drop down menu..
Thoughts?
Thx
Schoeps DOUBLE MS PLUGIN (2018) SURROUND PLUGIN FOR AAX finally available! bartosz idzi AAX Plug-ins 1 12-16-2018 03:49 AM
PROTOOLS 2018.3 Bounce delay compensation ERROR with UAD v9.5.1 AUX insert modulo2008 Pro Tools 2018 7 05-30-2018 02:10 AM
Pro Tools 2018.4 Hardware Insert Problem zion Pro Tools 2018 6 05-16-2018 03:22 PM
Bug: When selecting a favorite plugin insert, the plugin above the one selected opens DJ Hellfire Pro Tools 12 35 08-22-2017 08:05 PM
