Old 08-20-2015, 01:18 AM
Cryos's Avatar
Cryos Cryos is offline
Default Éucon bug with Fader layouts?
When I'm mixing I'm normally dealing with lots of tracks(100 and up) part of how I like to manage things is, as I'm working on a scene or section I'll hide empty tracks so I can have all sound elements more or less adjacent to each other on the time line (makes for better visualization and easier to grab blocks of faders) ...so far so good?...what I've discovered is this (and it's not consistent either) say I've hidden tracks 2-5-7 so tracks 1-3-4-6-8 are all adjacent to each other...however when I look at the artist mix pack not all the faders follow the same order, in protools they are but not on the fader packs. The faders on the Artiist Mix still keep the hidden tracks on the mixer, unfortunately this issue is not consistent either... anyone else seen this?
Cory Rizos, CAS
Re-recording Mixer/Sound Designer
Montreal, Quebec
http://www.imdb.com/name/nm0007185/
coryrizos.com
Old 08-20-2015, 11:18 PM
smurfyou smurfyou is online now
Default Re: Éucon bug with Fader layouts?
Are the faders in question set to Auto track assignment? IIRC when I use show/hide groups the hidden tracks disappear from the surface. Otherwise it would really mess with my head....
~Will
Old 08-21-2015, 09:41 PM
Cryos's Avatar
I belive they are set to auto track assignment...hmm...makes me think of something else....I have 2 mix units..the 2nd unit usually has fixed vca's assigned to it...maybe that's what's causing the issue? I'll experiment..
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
Old 08-22-2015, 04:42 PM
I usually leave a Control set to VCAs and the Mix to "Auto".
~Will
Old 08-22-2015, 07:49 PM
Cryos's Avatar
It's the mix pack that's set to auto that I've been getting the intermittent issue with...I'll see what happens if I set all the units to auto if the issue still happens..
Cory Rizos, CAS
Montreal, Quebec
coryrizos.com
My saved Eucon Layouts just randomly Disappeared! bobbyguelz Artist Series 0 07-28-2015 11:26 AM
Assign Fader layouts to soft keys...? dumbeat Avid S1, S3, Dock and Control App 3 05-05-2015 03:57 AM
Avid Artist Mix Eucon - Switching between Layouts silentmoon Artist Series 2 03-09-2013 07:42 AM
EuCon 2.6.0 PT9 Mix Screen Still NOT following fader bank... Fidelis Artist Series 29 08-08-2012 04:15 PM
Recalling fader layouts on MC Mix only? Schottlandru Artist Series 13 10-21-2011 01:08 AM
