Old 06-05-2012, 07:21 AM
aldersyde aldersyde is offline
Default keeping mixer view open
Is there a way to keep the mixer view on top when I click outside the mixer window?
Old 06-05-2012, 11:24 AM
Default Re: keeping mixer view open
On top, no(its a function of the OS) but visible, depends on your screen setup. With 2 screens(I run a pair of 22" LCD's) I would keep the EDIT window on the left and the MIX window on the right screen.
Old 06-05-2012, 02:47 PM
Raoul23 Raoul23 is offline
+1 on that
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 06-05-2012, 08:48 PM
bblack1023 bblack1023 is offline
Just use the shortcut to go between screens. Command+Equals(MacOS) and Control+Equals(Windows)
Old 06-05-2012, 09:46 PM
WernerF WernerF is offline
Yup, that works great on a 30" screen here. Hard to imagine why you would need to see both views at the same time. Toggling between the two works just fine as the keyboard command takes a mere millisecond to switch between the two views.
Old 07-04-2022, 01:35 AM
nOrakat's Avatar
nOrakat nOrakat is offline
Nope its terrible. That requires 2 hands - ctrl + '=', when you can just click on the window if it were on top somewhere.. I also like tab in Ableton where it is one button to switch views.
Pro Tools 2018.12.0 (64 bit version) on Windows 10 Home, PC: i9 12900K w 32 GB
Old 07-04-2022, 03:12 AM
Sardi Sardi is offline
You must have VERY small hands or an odd keyboard.
It’s most definitely a one handed shortcut.
Old 07-07-2022, 02:06 PM
Well, 2 screens is my best advice, but a second option is a used Gen 1 Presonus Faderport. It has buttons for MIX and EDIT(labelled "Proj") windows(plus the rest of the features are handy and cool too). Maybe if you describe your complete setup, there may be other options
Old 07-07-2022, 03:10 PM
Ben Jenssen's Avatar
After many years of using the dual display setup for seeing both edit and mix windows all the time, I've now found that all PT windows on one screen works better for me. I can switch between edit and mix with a mouse click because I let some of the mix window show at the top and some of the edit window show at the bottom.
I have one 50" tv that I use when standing up in the middle of the room (kinda my sweetspot) using my controllers more than the mouse, and beneath that a 32" that I use when sitting down for more detail for mousing around, editing, setting up stuff. Also it's color calibrated for photo editing.
The reason I have all PT windows on one display is that it's easy to hit 'mission control' (F3), grab the PT icon and drag it to the other display, and all PT windows follow neatly*. I find it much tidier than my old way with dragging separate windows to different displays and manually organizing it.
*'Group application windows' in system prefs, mission control, has to be enabled for this to work.
Of course, this is on mac. I don't know about windows.
Old 09-11-2023, 03:36 PM
nOrakat's Avatar
Its terrible they haven't added this simple option. When having to go back and forth often, you don't want to have to press any keys or click on anything every time.
How can I keep my mixer view in view? Sam C macOS 14 05-16-2013 02:16 PM
Color on Mixer View Gons Deejay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-29-2008 11:29 AM
Keeping Mix and Edit windows open Mike62858 Pro Tools M-Powered (Win) 4 12-21-2006 01:54 PM
Keeping tracks in phase due to mixer ch. inserts bryanbassett 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 09-27-2002 03:05 PM
Keeping mixer settings poppy Pro Tools TDM Systems (Mac) 3 09-23-2002 03:20 PM
