Old 06-12-2002, 02:46 PM
citi citi is offline
Default I Need Clarification. Difference between Multi Channel and Multi Mono Plugs
Hey guys,
OK am mixing a session that is pretty intense, the usual 24tracks 3 or 4 aux and some waves plugs when I got the 9128 error when I put the truverb into the track. I hit ok removed the plug. Sometimes if you remove it completely it resets the track so I did it again and 9128.
On the last try I accidently used multi channel verses multimono and not only did it allow the plug, but it dropped the cpu usage like halfway down.
What am I missing? What is the difference between the two and why does one use so much more power than they other? It's the same plug. I don't understand.
Thanks in advance!
CiTi
http://www.checkonet2ent.com
Old 06-12-2002, 04:26 PM
Default Re: I Need Clarification. Difference between Multi Channel and Multi Mono Plugs
Nobody knows? or nobody wants to answer? Come on guys.
CiTi
Old 06-12-2002, 04:33 PM
ReniuR ReniuR is offline
My guess would be that a multi channel plug will do some interaction between the channels and a multi mono will only process as if you sent it to 2 seperate plugs hard panned. This would make sense as to why the CPU usage is different as well.
If I'm wrong, please clarify, cuz I'm curious too.
-ReniuR
www.disposableproductions.com
Old 06-12-2002, 04:40 PM
You understood me just fine. I never thought of it like that. It is very possible that it is using twice as much power because it processing the left and right channel as individual channels. Funny though, you would think that the stereo would do the same when you consider panning.
CiTi
Old 06-13-2002, 11:08 AM
Jorge442 Jorge442 is offline
<font size="2" face="Verdana, Arial">multi-mono acts as 2 separate mono processors that´s maybe why the extra cpu load.
multimono sounds better to me BTW
jorge
what a long, strange trip it´s been
www.abacomusic.com
Waves Multi Mono Plugs Only Effects Left Channel Now ThaRemedy General Discussion 2 04-11-2009 05:23 PM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Post - Surround - Video 0 06-08-2007 09:06 AM
Multi-channel vs Multi-mono plugs on 5.1 tracks geitz Pro Tools TDM Systems (Mac) 0 06-07-2007 02:54 PM
multi-channel vs. multi-mono plug-in pinstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-02-2005 11:59 AM
Multi Mono vs Multi Channel Plugins...Just curious... Mr T 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 03-18-2002 09:46 PM
