Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-23-2019, 01:43 PM
Rob S Rob S is offline
Default Import Session Data or OMF Import creating regions of white noise
Hi there,
I have been using Pro Tools since version 6 and have never encountered this problem before.
Over the past few weeks I have had two different sessions and two different methods of session data import cause the same problem, that being regions being imported as full scale white noise.
Firstly, I had it with an OMF. I got a new version of the file and still the same issues. Was never able to fix it and had to do a major work around.
Then this weekend I build a show (audio only) from various sessions that I have edited over the week. Nothing complicated, an interview and VO and some clips.
After everything is edited in three or four files I bring them in using Import Session Data and line them up and mix. Never ever had a problem with this, 65 episodes...
What I got, again, from one session only, was full scale white noise. I checked back to the original session file, which opened fine.
So, I did a Save Copy In and rebuilt the session file. Same issue. In the end I had to import the raw audio into my main session and re-edit it.
Any ideas? I am totally at a loss. Everything else is totally fine and not having any issues.
I should add I am using a Mac Mini, Pro Tools 2019.6, everything up to date and High Sierra.
Thanks,
Rob
import session data creating unwanted trim automation zakco Pro Tools 10 1 11-27-2013 02:51 PM
PT9.0.2 regions dont appear in tracks after Import session data Steven1145 Pro Tools TDM Systems (Mac) 1 04-14-2011 10:06 AM
Regions not showing on Timeline when Import Session Data migbook Pro Tools TDM Systems (Mac) 4 03-18-2011 01:51 PM
Import session data not importing regions krop015 Pro Tools TDM Systems (Mac) 6 12-11-2010 03:29 PM
White Noise on PT 8.1 mac session import application4 Pro Tools TDM Systems (Win) 2 12-06-2010 05:10 PM
