Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 12-23-2013, 01:17 PM
mega.riviera mega.riviera is offline
Default Driver or firmware problem with Fast Track Pro USB and OS 10.9.1
I have updated the Fast Track Pro drivers 1.9.4 as well as the firmware for my Fast Track Pro I get any sound output (from every source like abletone live, itunes, browsers...) I do not have Pro Tools, should I own the program to run the driver properly? I didnt' get it.
The system recognizes the AI when I turn it on
Old 12-23-2013, 02:00 PM
Alkalinepablo Alkalinepablo is offline
Default No Audio from Avid Interface on Core 2 Duo Mac with OS X Mavericks
Hi, im having problems with my mbox 3 since i updated my imac from mountain lion to OS X Mavericks.
I cant use my audio monitors and already install the latest drivers and nothing happens.
Please help!
EDIT: Please see http://duc.avid.com/showthread.php?p=2125365
Old 12-24-2013, 05:23 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Mbox 3 Not working with OSX Mavericks
Can you please post what DAW and your full system specs: http://duc.avid.com/showthread.php?t=336556 the more info the better.
There have been other reports of issues with Mavericks and the latest driver, is rolling back to 10.8 a possibility for you?
I'll add your thread to the list, I have asked for an update or eta, but all I have at this time is that it is being investigated.
Joel
Jam Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2020 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 12-24-2013, 05:27 AM
JoelG's Avatar
Default Re: Driver or firmware problem with Fast Track Pro USB and OS 10.9.1
Can you please post your full system specs. There have been a few other posts about the Fast Track drivers and Mavericks (also Mbox devices). I have asked for an eta or an update but I don't have anything concrete other than it is being investigated.
I'll add your thread to the list and post back when I have anything to pass along.
You do not need Pro Tools to use the Fast Track or any version of the drivers. If rolling back to 10.8 is an option for you, it might be the best course of action until there is a solution.
Joel
Jam Space:
Home:
Rig:
Old 12-31-2013, 02:03 AM
Ghetty Ghetty is offline
Could you solve the problem? I have the same issue ...
This is the gear I'm using:
OSX 10.9.1
Macbook Air Late 2010
2,13 GHz Intel Core 2 Duo
4 GB 1067 MHz DDR3
Pro Tools 10 and 11
MBox 3 Mini
The MBox is shown up in the OS audio preferences, but that's it. No Output and no input Signal.
My old system was ProTools 8LE, same MBox, same computer - just another OSX and apparently another ProTools.
Old 01-01-2014, 02:09 PM
saywut saywut is offline
I've had the same issue since October. No luck. You can read my post and what i've done. At this point, i'm getting a new interface, probably a Motu and selling my mbox as it still works with my macbook pro.
Old 01-01-2014, 04:16 PM
Ghetty it would be helpful if you posted the exact Mbox driver and version you have installed. And whether you have tried uninstalling and reinstalling the driver.
To confirm what kext/driver is installed the kernel. In a Terminal window type
/usr/sbin/kextstat | grep avid
and
/usr/sbin/kextsstat | grep digi
and paste results here.
Old 01-01-2014, 10:13 PM
liferhythm9 liferhythm9 is offline
This must be a software issue not a hardware .. AS for MAvricks only PT 11 drivers are out as of yet
Old 01-03-2014, 12:51 AM
Snarf Snarf is offline
I´m having the same problem. No audio.
Latest drivers for the MBOX.
Specs in my signature.
Stian Sylta
Producer/Songwriter/Musician
Sons Of Vanity on iTunes/Spotify
MacBook Pro i7/Apogee One/Duet/ElevenR/Pro Tools 12
Preamps from UA, Mackie and Avid.
Listening through Dynaudio, Genelec and ADAM
Old 01-03-2014, 09:09 AM
It's definitely a driver issue. PT is independent in this scenario as there is no sound from any application.
Pro Tools Core 11.1 Audio buggy on mavericks ianmiller Pro Tools 11 1 01-24-2014 06:40 AM
Can Avid HEAT run in PTHD 10/11 without an Avid Audio Interface or HDX Card? hatepop Pro Tools 11 1 12-19-2013 01:26 AM
882 1/0 audio interface with mix core card pmurf Pro Tools TDM Systems (Win) 1 02-24-2004 11:00 AM
Core Audio/192 Interface only 8 outputs?? mike16877 Pro Tools TDM Systems (Mac) 1 01-02-2004 05:13 PM
Core Audio X: Live & PT sharing audio interface? ashdot Pro Tools TDM Systems (Mac) 1 04-03-2003 10:59 AM
