Old 11-26-2007, 07:21 PM
teacherman teacherman is offline
Default Did Digi put \"this\" feature back in 7.4?
In earlier version of Protools (7.2 and 5.3.1...though not quite sure about 6.x), Quick Punch used to flash the record button when a track was record enabled and the transport was running and then turned solid when you pressed it and then flashed when you pressed it again. It no longer does that in 7.3. Now record button only turns red when pressed.
This feature mysteriously went away with 7.3.
I have 2 older HD Protool rigs (5.3.1 running on OS 9.2.2 and a 7.2 rig) that both systems share a Procontrol and a D-Control respectively. The record button does indeed flash on the transport controls when PT is in QuickPunch.
My newest PT rig is running 7.3.1 cs5 with an accompanying D-Command. But now the recording button does not flash on the transport control when PT is in QuickPunch.
Thanks.
27" iMac; 32gigRam; OSX Catalina 10.15.2; PT 2019.12.0; Apollo x8p; UAD-2-Satellite-TB3-Octo;
Old 11-26-2007, 07:55 PM
c-tone c-tone is offline
Default Re: Did Digi put \"this\" feature back in 7.4?
I am running 7.2 and it doesn't work that way for me (no flashing red record button on the transport while in record ready / quick punch mode). The channel's record button flashes red, but not the transport's record button.
www.clifnorrell.com
Old 11-27-2007, 11:54 AM
Apparently I got a unique version of PT 7.2 as well as 5.3.1 because I've got a flashing record button on both the ICON and Procontrol's transport as well as the software's transport when PT is running QuickPunch.
Sorry that everyone else is missing out on this.
This is a great feature because...I always leave ProTools in QuickPunch because if I accidently leave a track in record, the record button on the transport will immediately begin to 'flash' when I hit the play button.
Old 11-27-2007, 01:05 PM
Aha. Probably, the different controllers are making the difference. I am not using a controller.
www.clifnorrell.com
Old 11-27-2007, 01:17 PM
sleadley sleadley is offline
From what I remember, the record light will flash if there is a pre-Roll turned on, but will not flash if it is turned off. I am not next to my computer but That was certainly the case for a second Pro Tools system chasing our Main system when we were creating mix stems. Give it a try and let me know.
Simon L.
Plan for the worst, Hope for the Best.
www.trackdown.com.au
Old 11-27-2007, 02:22 PM
Hey sleadley,
Oddly, In my case, the flashing record button does not have anything to do with pre roll being turned on or off. When I turn preroll on, the record button flashes; when I turn preroll off, the record button flashes.
Yes. In PT 7.3.x (and I assume 7.4) , the record button does flash but only when preroll is turned on.
Old 11-27-2007, 02:23 PM
Drew Mazurek's Avatar
How about MIDI Merge? Could that be turned on?
www.drewmazurek.com
Old 11-27-2007, 02:30 PM
Hey c-tone,
Actually, the controllers (either the Procontrol, Control 24, D-Control or D-Command) don't have anything to do with it. I can disable the console and disconnect the Ethernet cables and use only the software transport bar (windows>transport) and the record button still blinks.
Thanks
Will Digi ever add the feature... cary chilton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 07-28-2009 09:55 AM
Is there a talk back feature on the PTLE 002, If not? TheStriker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-23-2008 12:09 PM
Digi...cool feature for v5.3.... PeeTee Pro Tools TDM Systems (Mac) 1 01-07-2002 06:14 PM
ATT DIGI Feature Request 2 tomhartman Pro Tools TDM Systems (Mac) 0 12-17-2001 10:11 PM
feature request digi tomcat Tips & Tricks 6 08-24-2000 08:40 PM
