Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Win)
Old 06-28-2019, 11:55 PM
senghor senghor is offline
Default Pro Tools I/O and Focusrite Scarlett
I just bought a Focusrite Scarlett 18i8 with 4 input.
Pro Tools 2019.6 shows only 2 analog input (installed the drivers; went ok) How can I get Pro Tools to show all the 4 inputs in PT. I tried to resolve this on Focusrite's site and on Youtube, but no answer to this. PT's Playback Engine shows Focusrite ASIO. Is it ok?
Anyone knows how to get PT to show all the 4 analog inputs?
Thank You!
Win10 Home Premium, SP1
Intel i7-4770K @3,5GHz, RAM 16GB
GA-Z87N-WIFI (rev. 1)
Scarlett 18i8 and pre-amps, Pro Tools 2020
Old 06-29-2019, 12:19 AM
Default Re: Pro Tools I/O and Focusrite Scarlett
Go to setup>IO>Input and click the default button, same for output and bus pages.
Old 06-29-2019, 01:31 AM
Thank You! This resolved all. GREAT!
Old 02-01-2020, 03:31 AM
paflechat paflechat is offline
Hello,
can I ask if you then see 6 outputs in I/O Setup of Pro Tools (4 mono analog + SPDIF) ?
I'd like to create a 5.1 output, even if I only use the analog outputs for LCR monitoring...
Old 02-01-2020, 01:00 PM
Originally Posted by paflechat View Post
Hello,
You need to read your 18i8 documentation. The S/PDIF Out is not a discrete output, it normally mirrors 1&2.
Old 02-01-2020, 03:58 PM
You're right, thanx. But it seems to be possible with the 8i6 !
Old 04-23-2020, 10:05 AM
wardal1@me.com wardal1@me.com is offline
Since updating to PT 2020-3 I'm not getting any input from my focusrite 212, I have done everything regarding the settings I/O deleted and reassigned default all to no avail.
What am I missing??
On OS 10.13.6
Old 04-23-2020, 11:50 PM
What am I missing??
On OS 10.13.6
You are posting onto a thread about a problem with an 18i8, and it does not sound like it's related to your problem. Why don't you start your own new thread and include the following into/things to try:
"not getting any input"... what does that mean? Do you see the track meter move and just not hear anything? Or no meters as well?
Can you play back existing recorded content? What exactly happens, what do you see happening on the screen and hear.
What exactly did you change? (any OS updates done as well?)
What exactly are you seeing?
What exactly are all the options that show up in the Setup>Playback Engine>pPayback Engine menu?
Is the 2i2 selected as that playback engine? Double check it is.
What happens when you test with Built In Output selected as the PlayBack Engine?
You should already have tried trashing prefs, part of normal troubleshooting... see under "help us help you" up the top of each DUC web page.
Issue using Pro tools First with Scarlett Focusrite 2i2 michele70 Pro Tools 2018 3 05-07-2019 03:02 PM
Does the Focusrite Scarlett 2i4 work better in Pro Tools 12 than in 11 baumjoe Pro Tools 12 3 10-28-2015 04:27 AM
Pro Tools using Focusrite Scarlett 2i2-working!! baxteradio Pro Tools 12 1 09-08-2015 11:55 AM
Pro Tools 11 with Focusrite Scarlett 18i20? hermonmusic Third Party Interfaces 24 06-27-2015 08:53 AM
Pro Tools 9 and Focusrite Scarlett 8i6 - Problems! willyguitar Pro Tools 9 0 11-28-2012 03:57 AM
