Old 05-27-2010, 05:47 AM
antiwebbite antiwebbite is offline
Default Import Audio Files to Same Track
Hey Guys,
This seems like an easy thing to do, but I can't figure it out...
I have a large group of dialog files that I want to import onto the same track. Whenever I import them, they all go to their own individual tracks.
Is there a way to import them all to the same track?
Thanks!
EDIT: Using LE 8.0.3
Old 05-27-2010, 06:17 AM
spidey01 spidey01 is offline
Default Re: Import Audio Files to Same Track
when you are importing pro tools will ask if you want a new track or to import to the redion bin choose the region bin, then drag to the track where you want them to go
Old 05-27-2010, 06:20 AM
Thanks for the reply!
I tried that initially...but the only way I could get that to work is to drag file by file...I am working with hundreds of files and that would just be a waste of time.
Am I not understanding you correctly though, is there a way where you highlight 100 files in the region list and then drag them all at once to one track?
Old 05-27-2010, 06:17 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
In the region bin drop-down menu there's an option: Timeline Drop Order.
Choose Left to Right.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 05-27-2010, 06:53 PM
Craig F Craig F is offline
my idea of were the top/bottom or left/right select should also be
http://protools.ideascale.com/a/dtd/22488-3779
Thank you,
Craig
Old 05-29-2020, 06:58 AM
Skwaidu Skwaidu is offline
This still needs to happen. Also to auto-spot the files on import.
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
Audio Files cut off on import Maxheadroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-13-2023 12:01 PM
Import Audio Is Not Copying Files To My Audio Folder zwatrif Windows 12 11-14-2017 09:32 PM
Does "Automatically Copy Files on Import" work with Import Audio command? leftalive Pro Tools 10 3 04-17-2013 09:35 PM
Import Files To One Track GTBannah Pro Tools 9 6 03-12-2012 09:32 AM
Import Audio not 'saving' to audio files folder.. prkm123 Pro Tools TDM Systems (Mac) 5 07-18-2011 02:31 PM
