Old 11-07-2018, 11:40 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Eleven Rack ignored ProTools
Do you mean the Eleven Rack monitor is always ON?
Like this
https://youtu.be/TbRnyt6PVjc
This has already been reported to Avid (again) recently.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 11-07-2018, 11:43 AM
Nobody else is reporting this problem, it likely is something specific to your systems, there is probably nothing for anybody else to investigate.
Can you test the Eleven Rack on another system? The symptoms you have are of the local monitoring path muting not happening. Which (unhelpfully) could be caused by hardware, driver or Pro Tools issues.
If you can roll back and if the problem goes away you know it's some software/driver issue on your system. Or grab a spare partition and do a clean macOS install and bare minimal driver, ILM and Pro Tools install and see if that works. If' you'v been doing in-situ macOS upgrades that's higher risk that upgrades mess things up.
You can also try doing a memory reset on the Eleven Rack. I think there may have been some failed Eleven Racks in the past where the automatic muting of local monitoring stops working. Certainly have been problems on Windows with messed up driver installs that can cause that.
Old 11-07-2018, 11:56 AM
cryshark cryshark is offline
to benoni - That's the problem!! Unfortunately, switching low latency monitoring does not help. :-( that would have been a big deal.
Old 11-07-2018, 12:09 PM
I want to try that. I have an iMac i7 in the studio tomorrow. There it works without problems. but that's too dangerous for me. Here it has worked well until I have updated to 2018.10.
If someone could test it!
Old 11-07-2018, 12:19 PM
Like this
I think that's only been reported in the past by Benoni and others on Windows? (what I was referring to in another post). I'm not sure this has been seen by others on Mac... or this could new a new report of it. If toggling low latency monitoring fixes this then letting Avid know its being seen on Mac would be great.
I don't have this problem with 2018.10 (full clean install on *Mojave* (so different) on a 2017 MBP with latest Eleven Rack drivers (so same)).
  #16
Old 11-07-2018, 12:44 PM
Benoni's Avatar
It has recently been reported on Mac and logged as a bug.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #17
Old 11-07-2018, 12:47 PM
Benoni's Avatar
What exactly did you change before this started?
I can't test it as I use Windows.
Brian
Pro Tools 2022
benonistudio.com
Plugin Deals
@benonistudio
  #18
Old 11-07-2018, 10:41 PM
I only updated to 2018.10. I only use my Mac for music. A Scarlett 2i2 works without problems.
Gesendet von iPhone mit Tapatalk
  #19
Old 11-08-2018, 10:36 AM
Hello, I have a new insight. On my Mac Mini 2012 i7 with High Sierra and ProTools 2018.1 the same problem. Looks like the device itself has a defect.
  #20
Old 11-08-2018, 10:39 AM
You can try a user options > memory reset on the front panel. Otherwise a used or new Eleven Rack is pretty cheap.
Eleven Rack Re-Amp monitoring not working Ennimusic Eleven Rack 13 04-19-2015 12:25 PM
Eleven Rack monitoring? saheyl macOS 1 02-01-2013 10:53 PM
Eleven Rack & in-ear monitoring DonaldR Eleven Rack 1 03-10-2012 05:50 PM
Vocalrecording - Eleven Rack - Low Latency Monitoring? wiseman Eleven Rack 8 07-01-2011 06:52 AM
Direct Monitoring with Digi 002 Rack iCymiCy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-31-2009 07:03 AM
