Old 02-18-2019, 04:17 PM
bonzerboy bonzerboy is offline
Default Stereo or Multi mono Buss compressor
Anyone see any advantages of using a multi mono compressor on a mix buss instead of stereo?
Wow am I groovy or what
Old 02-18-2019, 04:39 PM
amagras amagras is offline
Default Re: Stereo or Multi mono Buss compressor
It depends, I mix a good amount of Afro-Cuban stuff which is heavy on toms and other panned percussion so I use multi mono, the same with the limiter and most instrument groups.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools 2018
amagrasmusic.com
Old 02-18-2019, 05:25 PM
I could see that but what are your thoughts on using multi mono on the final master Buss ?
Old 02-18-2019, 05:57 PM
Sardi Sardi is offline
It can increase width but it can also skew the stereo image.
Like most things, it’s not a one size fits all.
Old 02-18-2019, 06:05 PM
Exactly, I discovered this the hard way (like everyone else I suppose), I was mixing a song and there was a point where I couldn't make it sound more clear then I realized it was the master channel and all the processes in stereo, it was heavy on toms. In pop mixes where everything is equally spread and there's no much rhythmic variety using stereo processes can help creating a more "glued" sound but dual mono preserve the stereo image better.
I can only write about my experiences but your best option is to use them extensively to learn to identify which one sounds better and when.
amagrasmusic.com
Old 02-19-2019, 10:40 AM
Or use a compressor that allows unlinking the sidechains from each other. That way you have a choice of how to go.
Old 02-19-2019, 02:22 PM
I remember having a compressor in multi mono and did not realize the settings were almost opposite of each other and created a mess in the print. that is what got me thinking why not use muti but i see as in anything audio,, listen listen listen
Old 02-19-2019, 02:56 PM
By default in Pro Tools both channels of a multi mono plugin are chained so you don't accidentally dial in different settings on each channel unless you want to.
amagrasmusic.com
Old 02-19-2019, 04:24 PM
that is what happened i un linked by accident and set one side
Old 02-23-2019, 04:36 AM
BillieWillie's Avatar
BillieWillie BillieWillie is offline
+1
Stereo Interleaved vs Multi Mono studiojimi Pro Tools TDM Systems (Mac) 17 12-08-2009 11:20 PM
mono to multi mono or stereo? Dean Smith 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-21-2006 02:32 PM
Multi Mono Or Stereo? M2E Pro Tools TDM Systems (Mac) 1 07-04-2005 11:30 AM
What's your favorite stereo buss compressor plugin Imagine Pro Tools TDM Systems (Mac) 31 02-11-2005 03:02 PM
multi mono/stereo inserts corTools 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-02-2004 12:11 PM
