Old 01-15-2005, 05:19 PM
eljodon eljodon is offline
Default ProTools 6.7 freezes at \"loading DAE objects\"
I decided to upgrade to HD3 Accel and used my old G4 800 Quicksilver,which was very stable.Then I decided I needed more power and bought a G5 Dual 2.5.It's got 2 gigs of RAM,and a new Atto ExpessPCIUL4D.I'm using my old Digidesign 32 bit expansion chassis(the G5 has only 3 PCI slots)Now when I start ProTools after all the plugins are loaded,at the part were you start seeing"loading DAE objects" it freezes and shows a empty dialog box that only says cancel or ok.I have to force quit.Anybody has any idea was going on.My Quicksilver G4 800 worked instantly.Thanks.G.A
Old 01-15-2005, 09:43 PM
Farmer Dave Farmer Dave is offline
Default Re: ProTools 6.7 freezes at \"loading DAE objects\"
Not sure, but unless you need them for Digibase, trash, on EVERY mounted drive, the:
Digidesign Databases Folder
In PT6, this has fixed, all kinds of PT errors, including ones where PT won't finish opening (and I'm talking the app itself, not just a session!)
PT makes one on every mounted drive (even a compactflash card), so dump 'em all! Give that a try & let us know.
Good luck!
Old 01-16-2005, 02:02 AM
Thank for your response.I managed to make my Expasion 32 bit 7 slot Chassis(DD007-R) to work with only the Core card?!?!When I put the rest of the Accel card,it does not recognize my 192 i/o.I placed the cards in the order that the manual said any clues?G5 Dual 2.5 2G ram,10.3.5,Atto ExpressPCI UL4D.Wow this G 5 boots up fast.G.A
Old 01-16-2005, 09:47 AM
Hang on, I remember something similar in my original setup. Try connecting the interface to the last Accel Card, instead of the Core. Mine is still set up that way, and I know at least one other person that went thru this.
So my card order is
Core
Accel
Accel (with interface (96i/o) connected)
Old 01-16-2005, 10:33 AM
Thank you Farmer Dave,I will try that tonight,I was wondering why it worked when I took the 2 HD Accel out of the Digidesign 7 slot 32 bit Expasion chassis and only used the Core card and it finally recognize my 192 i/o.When you perform the Digitest it shows the cards in a backwards other,even when the Core card is in correct slot!!I just hope it will be as stable as it was with my wimpy G4 800 Quicksilver.Digidesign should post this on the website unless is just us 3 people.Thanks G.A
Old 01-16-2005, 11:09 AM
Hey Farmer Dave,I just tried what you told and it worked(could not wait until tonight)I'll put the system thru the "real"test tonight and will see.G.A
Old 01-16-2005, 03:40 PM
maxserg maxserg is offline
I'm not shure but don't you need to upgrade your exp. chassis to a 64bits with the G5 and PTHD?
Old 01-16-2005, 06:44 PM
No Maxserg:Thre are some 32 bit that are approved by Digidesign and they "say" the only limitation is 128 tracks,which for now is fine for me.I hope thats the only thing.G.A
Protools 8 Freezes at "Creating Dae Objects" upon Launch? MythMuzik 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 04-22-2011 07:53 PM
Protools freezes at the loading dae screen TheKlasix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 08-10-2009 08:43 PM
Protools LE 8 freezes when loading! musiclovin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-11-2009 10:49 AM
Protools 5.1 LE freezes when loading (DAE is stuck?) blazer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-28-2002 12:03 AM
system freezes on first loading of protools le during LAUNCHING DAE screen boy365 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-22-2001 10:22 AM
