Old 05-08-2005, 09:53 AM
noequipment noequipment is offline
Default 24/192khz on benchmark DAC-1?
guys, how to do 24/192khz files with DAC-1 connected via AES/EBU on HD3 with 192i/o? i tried to work around it..seems i got error on DAC-1. anybody mind to share the experience?
noequipment!!
Old 05-08-2005, 06:10 PM
Default Re: 24/192khz on benchmark DAC-1?
bump..
Old 05-08-2005, 06:24 PM
lancejorton lancejorton is offline
i've had one a few months and never tried it above 96kHz. i'll check it later, but you may need to call Benchmark if you can't get it working.
lance
lance
Old 05-09-2005, 12:32 AM
i tried on 96khz..smooth, but got error message for above 96khz. I read that 192khz was dual wire thing? but just found out that mini DAC will do above 96 without special setting. anyone can share experience with other unit?
noequipment
Old 05-09-2005, 01:37 AM
Imagine Imagine is offline
There was an upgrade on the DAC which would allow you to playback at 192k. Here's what you do!
Check the frequency of the crystal oscillator. The 192 kHz boxes have a 28.322 MHz crystal oscillator. The older units have a 25 MHz oscillator.
Remove the top cover. There are 4 small screws on each side of the cover. Do not remove the bolts on the front plate, or any of the screws on the rear plate.
The oscillator frequency is clearly marked on the oscillator can.
If you DAC1 doesn't have 192k marked on the oscillator can, you might have to send it in for the upgrade.
Dean
Old 05-09-2005, 03:05 AM
my unit was the latest version with stepped attenuator and i believe it was 192Khz ready cause the box and the unit say so. but good advice, I'll check it out. I emailed benchmark about this and still waiting the answer. I'll spill it here.
noequipment
Old 05-09-2005, 08:04 AM
update. benchmark just told me that earlier 192i/o would not do 192khz on digital output? is that true? anybody here can enlight me? digi?
noequipment
Old 05-09-2005, 05:47 PM
Update!!1...
the problem is not DAC1 but from digital ouput of 192i/o that only do 96khz in single wire mode. above that need dual wire mode, while the DAC1 is in single wire mode. thank to John Siaou who do research for me. It's on 192i/o manual page 7.
noequipment
192khz recording capt kirk Pro Tools 9 1 02-12-2012 09:16 AM
I cant go to 192KHZ KINGDRAGON Tips & Tricks 2 01-29-2010 11:57 PM
Anyone recording at 192kHz? Rupert Limehouse Pro Tools TDM Systems (Mac) 17 10-07-2009 11:36 AM
How many of you record on 192kHz? mantaray Pro Tools TDM Systems (Mac) 3 07-02-2005 09:18 AM
Possible configurations to *get* to 192khz Stephen J Pro Tools TDM Systems (Mac) 2 02-13-2004 10:25 AM
