Command 24 VS Control 24
All
I'm ready to move my project studio up a bit to a sexier control surface. I currently use a 002. I have been talking to Sweetwater about going to either a 003 or make the big jump to a C/24. Keep in mind that my goal is to eventially move into a HD system/environement vs LE. Also I'm simply using my studio to track and mix down demo material for Midwest 7-9 piece 60-70's R&B bands. While researching I see that there are a fair number of older Control 24 surfaces available. So here's my question(s). Why would I spend the extra dollars if a Control 24 would do the job? What issues should I be aware of? Is there anything with a Control 24 that will keep me from obtaining my HD goal? Are the Focusrite Pre's as good as they say? Were there not inherent issues with power supplies? Is there a vintage or pre/post serial number I should avoid? Lot's of questions. I'm sure that there a number of Control 24 users that have some great advise. Thx Nick |
Re: Command 24 VS Control 24
What is a Command 24?
Why would I spend the extra dollars if a Control 24 would do the job? The C24 is the newer version of the Control24. Both offer a lot of the same functionality, but the older Control24 has had some problems. What issues should I be aware of? Power supply and just plain age Is there anything with a Control 24 that will keep me from obtaining my HD goal? Not really, both C24 and Control24 are compatible with either LE or HD. Are the Focusrite Pre's as good as they say? Actually, they are as BAD as they say. Nobody really uses them, except for talkback, or someone on a really tight budget. Were there not inherent issues with power supplies? Yes Is there a vintage or pre/post serial number I should avoid? ??? The money spent on a Control 24(with fairly useless preamps) makes it an expensive controller(IMHO), but it really is a decent controller. The newer C24 does most everything, plus its newer mic preamps are more useful(again, just an opinion). Either way, you will want at least 1 really good "money" preamp. I would wait till AES comes and goes, just in case they pop something new. And take a look at this: http://www.solid-state-logic.com/music/nucleus/
Once the Control 24's Power supply has been replaced they are rock solid. Mine ran fine for years! As for the mic Pre's they are nice to have available. Would they be the only ones to use , no, but they are good to have around . I have recorded some decent things with them.
Marti D. Humphrey CAS aka dr.sound www.thedubstage.com IMDB http://www.imdb.com/name/nm0401937/ Like everything in life, there are no guarantees just opportunities. |
The main issue you should consider IMHO--and probably a reason to hold off until the PT9 dust clears--is whether or not the Control 24 works under PT9. I'm guessing it does, but it's unlikely to be officially supported. The C|24 is presumably more "future proof"...but of course it's also more costly (you can pick up used Control 24s for as little as $3K, whereas I think the C|24 is like $12K new). Personally I'm not a big fan of the pres on the Control 24. I think the C|24s are better, but I doubt you'd use them much if you have other boutique pre options available. |
command 8 /control 24 or other control surface for HD | 68topls | Pro Tools TDM Systems (Mac) | 0 | 12-26-2009 12:25 PM |
Control 24 / command 8 or other control surfaces with HD | 68topls | ICON & C|24 | 0 | 12-21-2009 05:47 PM |
Tactile control of PTLE without Command|8 Control|24? | Blackshapes | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-05-2009 09:39 PM |
Using D-Control/D-Command to control Pyramix | SoloMonk | ICON & C|24 | 1 | 10-18-2007 10:38 PM |
