Old 09-14-2020, 06:47 AM
ViciousLullabyz ViciousLullabyz is offline
Default DVS Sample Rate Switching
Hi
I've been very much enjoying my MTRX Studio the last few months and have figured out most of the features. One convenient thing it Dante Virtual Soundcard. I can have a desktop coreaudio output and listen to anything from macOS while having my HDX system engaged.
However there is one issue that i can't seem to resolve:
DVS connects via a Dante Input on the MTRX Studio. The MTRX Studio is set to follow the digilink sampe rate, which is usually set to 48kHz. When I switch to a 44.1 session, then i lose the desktop audio from dante, as the DVS does not automatically switch. I have to manually go into Dante controller and do that.
Is there a workaround for this? I also have Dante Via, but that doesn't seem to help in this scenario either. I there a way to have the Dante sample rate be a slave to my MTRX Studio sample rate and communicate that to DVS as well?
Any help or workarounds are appreciated, thanks
Old 09-14-2020, 10:07 AM
Top Jimmy's Avatar
If there is I haven’t found it either. I don’t think it can based on the way DVS works.
James Cadwallader
Old 09-14-2020, 11:08 AM
mixboy bob mixboy bob is offline
Default Re: DVS Sample Rate Switching
Same issue here... I just switch manually. Wish it could re-clock like all my other Dante/REDNET gear, but apparently not. Thankfully, I stay at 48k 98% of the time, so not huge for me, but I understand for some this could be many times per day.
http://www.robburrell.com
PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA
Pro Tools switching sample rate after quit Tobias Eichelberg Pro Tools 12 4 03-09-2017 01:52 AM
Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size sample Pro Tools 11 2 02-24-2016 01:04 PM
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
switching noises, sample rate changes, oxidation bigears 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-25-2005 04:35 PM
888/24 sample rate switching dekype Pro Tools TDM Systems (Mac) 1 01-21-2000 07:05 AM
